Question about HP Officejet Pro L7780 All-In-One InkJet Printer
I can't find what toner I need to get for this
I can't find what toner I need to get for this machine - all the answers are for ink cartridges not toners! help!
    Genius:
  • 1,018 Answers
First, place do not consider using refilled toner cartridges or third party toner cartridges.
They cause almost the same type of failures as ink cartridges.
I would simply start by calling a Office Depot, the shore where you purchased the Pinter or as a last ditch, contact HP. You can go to HP's web site and check under the Supplies and options and check under your model type.
Don
Posted on Feb 05, 2010
    President:
  • 2,306 Answers
The L7780 is an inkjet machine that doesn't use toner, have you given the correct model number for your machine?
After replacing cyan, magenta and yellow toners with genuine Canon toners, my Canon MFC 8180c does only use yellow color to print while trying to print or copy color stuff.
You will need to do an ink reset because from what you have explained the machine has only recognised one of the coloured inks and the black.
1. Switch on the machine and set it up for removal of all the ink cartridges . Then fully remove each of them (including the black) and then replace them back in the correct slots. Make sure they are fully home when you fit them. The machine now thinks you have removed used cartridges and replaced them with new ones.
2. Then close the printer and follow the instructions on the display window on the printer to indicate to the machine that you have replaced each ink tank with a new one.. It will ask in order if you have replaced each of the ink tanks from black onwards and the answer has to be yes. Make sure you hit the correct buttons when responding because if you do not the printer will not recognise the presence of that particular ink cartridge (and will not use it) which I believe is part of the problem you have now.. Check your user manual to make sure you are pressing the all the correct keys for your model machine.
Hope this helps some.
Dec 30, 2015 | Canon Office Equipment & Supplies
How to change laser printhead
Laser printers do not use a printhead.
When the toner runs out you need to get a new toner cartridge which includes the print drum.
You lift up the cover to reveal the toner cartridge, grab the cartridge and pull it out towards the front of the printer.
Reverse this procedure to insert the new toner cartridge.
Apr 09, 2012 | Brother MFC-8870dw Wireless Multifunction...
I have a universal color inkjet refill kit need to know to apply to my laserjet 4000 toner cartridge C4127X
Short answer: you cannot use any INKJET refill kit for a Laser Printer!
Laser Printers use TONER (e.g. powder) and not INK.
Hope it helps!
Sep 18, 2011 | HP LaserJet 4000n Printer
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
Toner dust
It really sounds like a defective cartridge. There is a metering blade in there that puts the right amount of ink onthe roller, if its not right it will just throw it into the machine.
You need to vacuum the machine out, return the cartridge for a new one.
Nov 03, 2008 | Xerox FaxCentre F12 Laser Printer
Toner
when they say TONER , its refering to the INK CARTRIDGES , Color & black ,
CANON PIXMA MP780 & MP750 uses the same INK CARTRIDGES :
BCI-3eBK for BLACK & BC-31C for color
please rate this solution , hope this helps
May 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
104 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
