Question about Freezers
Kenmore side by side water leaking from freezer
I have a Kenmore side by side Model No. 363.9565522. Noticed water dripping out of front of freezer onto floor - this has happened periodically over the lifetime of the side by side. Slid bottom freezer tray out and noticed a sheet of ice on the floor of the freezer. Also noticed ice adjacent to drain hole. I removed all of the ice using hot water, blow dryer, etc. and poured some hot water dow drain hole.
Two weeks later, water is again dripping out of freezer. While removing ice again, I noticed small droplets of water appearing (falling) on the back plastic wall above the trough that leads to the drain plug. Not sure if this was because the freezer door was open or another problem. Removed all the ice last night and again poured hot water down plug.
  • sheppardwk Feb 06, 2010
    I called about the kit and will try and pick it up next week - as I understand it, the bar will attach to the heater coil and insert into the drain. Looking at the freezer, I noticed that the ice is building up adjacent to the drain along the trough. I inserted a pipe cleaner down the drain to see if there was a clog, and it went in about 6-8 inches. If the drain is not clogged, then why is the ice building up along the trough? If I buy the kit, should I position the bar outside of the drain to heat the buildup of ice so it will flow into the drain? I've taken pictures, but I don't see how to upload them.
    Thanks again.
    Last night, I used a turkey baster and blasted hot water down the drain. I looked this morning and the ice has started to build up again adjacent to the drain and all along the trough. The drain is completely clear, so I'm still puzzled why the ice continues to build up. Someone suggested that maybe the freezer wasn't defrosting long enough to allow the ice to melt. I'll continue to watch it and buy the kit on Monday. Positioning the stem into the drain hole doesn't seem as though that will melt the ice along the trough, but I'll try.
  • 8,220 Answers
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Posted on Feb 05, 2010
  • Dan Webster
    Dan Webster Feb 06, 2010
    I have a wet dry shop vac and a heat gun. I melt the ice and vacuum out the drain. Most of the time that works but sometimes it don't no matter what you do. Hence the kit.
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
Kenmore water hose
If it is not connected to the freezer unit - it cannot make ice.. Ice is frozen water - you have connected a separate line that seems to have nothing to do with the fridge unit.
May 09, 2013 | Freezers
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Excess water drips throughout freezer during defrost cycle
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 01, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore leaking oil
Hi!!
You have a Refrigerant Gas (Freon) leak. Oil travels with the Refrigerant Gas thru the system, that's why you see the oil on the drip pans, if you look closely you should be able to know where is coming from.
For what you are telling me, it seems that the leak is of considerable size, I recommend to ASAP take freezer to a Kenmore authorized service station for a repair estimate, then you can decide to fix it or get a new one. If you call a repair tech, he will charge for the house call regardles.
Good Luck
Don't forget to rate this post.
Jun 04, 2010 | Woods Upright Freezer V1613RW3
I found water coming out of my freezer. What does that mean?
out the back?or front of the unit? if back thats defrost if front the drain might be plugged
Apr 10, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Evaporator coil in freezer red hot and water dripping on it.
This normal operation. Happens twice a day to defrost the freezer coils. Last about 20 minutes.
May 02, 2009 | Kenmore Freezers
Freezers Logo
397 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
