Question about GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It did not. I'm thinking there might also be a internal fuse? Pulled plug as per owners manual for power surge and nothing happened.
  • 34 Answers
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Posted on Feb 05, 2010
Testimonial: "That's helpful to know. Found a similar feedback, "is usually a 15 amp Cerramic fuse (white color). Appliance parts places usually carry it.thanks"
  • 72 Answers
If it took power out to your whole house you have a direct short in the unit, most likely place is the cavity tco mounted and the top of the cavity left side. I have had the connectors burn off and short to the casing
Posted on Feb 06, 2010
G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
Bill,
I have the same unit. It just happened to me. DId you find a resolution?
I was using it on the oven mode and it just stopped working. It's completely dead.
Thanks
Bob
Apr 11, 2010 | GE Advantium 120 Convection/Microwave Oven
How do you reset the microwave power? Is there an external circuit breaker if the main house circuit breaker did not switch off?
There is an internal cartridge fuse, as well as thermal fuses. It is not recommended that you attempt any internal repairs on a microwave due to the presence of very high voltages and the danger of microwave radiation if not reassembled correctly. Residential microwaves, if not under warrranty, are generally considered disposable. Parts and service are very expensive.
Feb 25, 2010 | GE Advantium 120 Convection/Microwave Oven
HOW TO GET SPATTER OFF ADVANTIUM 120. SOAP & WATER DID NOT GET THE JOB DONE
easy stick a bowl of water and stick it in the wave and boil it.. but be careful to let water cool before you open the wave for a minute or two ! the steam from the super heated water will loosen that stuck on mess .. boiling water in a m wave is dangerous the water will explode when exposed to cool air
Jan 31, 2010 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave power seems to have died
My advantium 120 died and it has power to the oven but it does not work! does the oven have a fuse that i can change?
Sep 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium - No power at all - PSB2201NSS01
Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
ALL POWER LOST
I am not sure I can solve your problem or perhaps you have already solved your problem. My thought is "are you sure your circuit Breakers are OK"??? In order to re-set a tripped circuit breaker you have to first turn them all the way off, then re-set them to 'on'. If you did not do that they probably did not re-set.
Assuming you did that correctly then I would have to suggest you contact prototech@usa.net. He/they might know of a internal fuse or other problem the may help you. Good luck.
****.sue@hotmail.com
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
357 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
