Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
External hard drive please helpmalfunctioned when
External hard drive please helpmalfunctioned when last used,now when it is connected to my p.c it is not recognised, can you
    Scholar:
  • 81 Answers
Well if the Ext. HDD is making any kind of noise like spinning up
and spinning down , or a clicking sound the unit may possibly
never run again , if the unit does boot but is not recognized by
your computer try troubleshooting start first with the power outlet
then the power cord then the data cord , make sure its running
when your computer is turned on , there is only one connection
from an Ext. HDD to the computer and that's its data cord , if its
a 3.5 HDD install it into a PC as a slave to try to recover the data
and never for any circumstances place an OS on your static Ext.
HDD , if your HDD never turns on again there are many services
online who specialize in HDD data recovery , if you attempt it
yourself you'll need a pretty close match HDD , a very clean
room a pair of non-powder latex gloves and some tiny Torx
head drivers , a clicking sound is the pick up heads , a spinning
up and down sound is the motor , if the unit needs to be formatted again you will loose the data that is stored on it
sorry I can only help so much , and troubleshooting is always
the best bet , try taking the enclosure case apart and make sure
everything is connected .
Posted on Feb 05, 2010
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
SimpleTech Simple Drive 250GB external hard drive not recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
May 22, 2010 | SimpleTech SimpleDrive...
250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive: My fiance used my elements hard drive as a time ma...
Hello
Kind Regards
Andrea
May 18, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
How can I turn my netork hard drive into a External hard drive
Network hard drive is also an external har drive but its shared over a network. If you want it to be used a external hard drive connected directly to you computer, read below.
Your WD drive should have a USB port on it. You need to plug the drive into your laptop directly to be used as a external hard drive.
Please rate if helpful.
Thanks
Apr 19, 2010 | Western Digital My Book Essential 1TB...
Iomega External Hard Drive Issue w/ iMac
Hello
Kind Regards
Andrea
Feb 27, 2010 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
Lacie external hard drive is not recognized in my
Hello
Kind Regards
Andrea
Oct 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
Seagate Free Agent Desktop 500 GB USB External Hard Drive is not working .... i think is totally dead. how can i recover all my data from that.. the big problem is the external hard drive when i attached...
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Kind Regards
Andrea
Mar 16, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
External Hard power is on but does not show up on my pc and does not seem to be running
what do using to connect the external hard drive.
if you are using usb, try a differnt machine first.
yes. you can disassemble the hard drive and connect it as second hard drive on your machine. provided they are the same configuration IDE to IDE SATA to SATA.
Oct 15, 2008 | Western Digital 250GB MyBook External USB...
External Hard Drive will not post "Cavalry Storage CAUI35160 Hard Drive"
if your hard drive making a unusual noise there something happened to the internal parts of the drive. does your hard drive accidentally dropped?
ok. check your jumper settings. set your jumper to slave. try it might work.
Jan 28, 2008 | Cavalry Storage CAUI35160 Hard Drive
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
247 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
