Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The green light is blinking inside the house on the opener button. The door works fine, but my alzheimers mother is in panic mode since the light is blinking. How can I get it to stop?
    President:
  • 3,197 Answers
Press and hold the button with the lock icon for 3 seconds.
Posted on Feb 05, 2010
Green light on prjector PRM 35 will not stop blinking and the projector will not come on
open the case, and reseat the ribbon cable at both ends.
5 screws on the bottom and 3 screws inside the lamp housing to open the case. Be careful not to break the 2 plastic clips in the back.
Also check the micro switch on the lamp door is working correctly.
Mar 10, 2014 | Promethean Board Promethean PRM-35 DLP...
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
We had a power blink during the night and the next day our garage door wouldn't go down, with the remote or even the house button, unless we hold down the house button until the door is completely down. No...
sounds like a problem in, i want to say the motor, but it opens fine, check your spring assembly, check your chain, and lastly, replace your opener, BUT FIRST, check to see if your garage door opener has a lock feature. most of them do, it disables all wireless remotes. if its only responding to the push of a wired button, then it may be in lock mode, find your manual. the lock button may be on the opener unit or the wall unit
Jan 05, 2010 | liftmaster Chamberlain Garage Door Opener...
My wired key pad in the garage opens and closes the door but the buttom keeps blinking fast. My two car remotes stopped working. My remote key pad on the house works. Whats with the fast blinking and...
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sensor lights not working on door opener
If the sensor light or receiver gets kicked, it can be knocked out of alignment. If it's not aligned, it will act as though it is blocked -- in other words it will open, but not close.
I fixed my buddy's opener not long ago -- you should have two parts of the sensor, near the floor at the bottom of the door. One is an infrared light, the other is a receiver. The receiver should have a little LED on it. This glows green when it is receiving a clear signal from the other side. If your's is glowing red when you can see that the path is clear, try adjusting the aim of the infrared light. You should be able to gently move the light from side to side until you see the LED on the receiver glow green.
Dec 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
145 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
