Question about Sharp 27H-S60 TV
Sylvania wont come on
Turn tv off, wont show picture. but can hear a hissing or buzzing sound.
Pls check the power supply ckt. the sound might come from the transformer of the power supply ckt. switching regulator maybe is not pulsating.
Posted on Feb 21, 2008
I have a sylvania 32in replacement tv circuit board model srt2232s It doesn't turn on anymore , fuse is good , buzzing coming from a transistor I think any thoughts . Thanks
Hi there, sorry to hear. That "buzzing" you hear is most likely that power supply onboard, pulsing in a failure mode such as a current limit situation. Check for shorted rectifiers, and the common bad capacitors.
Jan 21, 2015 | Sylvania Televison & Video
Emerson -modle ewf2704 . tv went out no picture no sound wont turn on but when pluged in you hear a buzzing sound
My 55" LG did the same thing. Had to have tech come to my house and replace board. It is a factory defect in alot of LG TV not sure about Emerson
Feb 12, 2012 | Televison & Video
My tv will not pwr up. grn light flashes then turns red.
I have a Sylvania LD320SS8A and I turn it on and the green light comes on and no picture???? Just black... I can hear some sound but no picture...
Feb 12, 2010 | Sylvania LC320SS8 32 in. LCD Television
When turning TV on it would click a few time, then you would hear a hissing sound, but no picture. Would have to unplug TV, as it would not power down. Unplugging and plugging in would eventually get...
The hissing sound could be high voltage leaking from a tripler. Observe in a dark room for blue arcing. Look at tripler and connections to the projection tubes. If the tripler is leaking replace the tripler.
Oct 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
My polaroid has sound and picture problems
This is a well-known problem with many Polaroid FP displays. Eventually, the picture will simply go black, rendering the TV useless. The solution is a new control board, ~$400.
Feb 27, 2009 | Polaroid FLM-4201 42 in. LCD Television
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
Televison & Video Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
