Question about Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT
Clutch removel on a poulan p4018wtl - Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT
    President:
  • 2,220 Answers
She has an inboard clutch. Do this to remove the drive sprocket.
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Use this as guide to remove remaining parts.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it.
Poulan PP4018 Gas Saw Type 2 IPL example (may not be your saw): I find these helpful with disassembly.
http://www.ordertree.com/modelinfo/PWE/PP4018-Poulan-Pro-Gas-Saw-Type-2/75.PP4018-Poulan-Pro-Gas-Saw-Type-2.1.59.1.html
Clutch detail on "Handle, Chassis & Bar Assembly"
If yours is not Type 2, find your saw here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
More questions or need additional help reply below. HTH
Lou
Posted on Feb 09, 2010
    Problem Solver:
  • 15 Answers
Remove bar nuts and cover, leave bar on and reinstall bar nuts. clamp bar in vise. usually clutch has an arrow showing direction to turn to remove. use hammer and punch and a strong tap in that direction should turn it off. warning this is not the recommended way of doing it but works in the shadetree!
Show me how to change clutch on 3314 p
Use a Poulan clutch tool and look at the clutch for the direction to rotate the clutch. There will be an arrow and It should be CCW
Sep 14, 2014 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How to install clutch on poulan pro 42 cc
Remove the clutch hub and sprocket, then using a Poulan clutch tool, unscrew the clutch assembly and replace.
Jul 25, 2014 | Poulan Garden
Cannot remove a/c clutch to remove shim. tried screwdrivers but worry about breakage. can i use penetrating oil? 1998 nissan frontier,198000 mi. works fine if you tap the clutch in with screwdriver. the...
they are pressed on and you need a ac clutch removel tool to remove them so you dont damage the clutch . you can buy the tool on ebay or check www.harborfreight.com about 50-89 dollars
Sep 25, 2010 | 1998 Nissan Frontier
How to repair Poulan Pro PP4018 with a bad clutch?
Hello Paul;
A link to a Poulan "PP4018 Gas Saw Type 2 follows (may not be your saw):
If yours is not a "Type 2" all IPLs can be found here:
The IPL (exploded parts list) for your saw is beneficial with disassembly/reassembly:
Poulan.com
The 4018 link has an inboard clutch the drive link is changed as demonstrated here (chain brake must be released else you cannot remove the clutch drum):
If the actual clutch needs replacement continue with the remaining pieces as follows (IMO if changing the actual clutch the bearing should be replaced too):
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 10, 2010 | Poulan Garden
How to remove the clutch from a poulan prolink
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool.... b61de2e.jpg
Jun 09, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How to remove clutch on Poulan Pro PPB350 gas trimmer
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool... That should work for you. Dwainb076e56.jpg
May 18, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Clutch removel
You have to remove the exhasut and trnamsission to replace the clutch.
Jan 14, 2009 | 1994 Buick Century
Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT Logo
357 people viewed this question
Top Poulan Tools & Hardware - Others Experts
L Pfaff
L Pfaff
Bill Boyd
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
