Question about Frigidaire Refrigerators
Ice maker not working-on off swich has burned area. do I need to have the entire ice maker replaced or just the motor part? Thanks Geri
  • 454 Answers
You can replace just the switch. Do an internet search for appliance parts. Select a retailer and enter the model number of your refrigerator/ice maker. This will bring up information about how to identify and buy the part you need. They have very nice exploded view drawings available to help you easily identify the part you need.
Posted on Feb 06, 2010
My Maytag M1TXEMMWWB00 (209 cu ft) Top Freezer Refrigerator will not make ice. I checked the solenoid where the water comes in to see if it has a current and it doesn't (no juice). I looked at the owners...
The ice maker tells the water valve to open so you will not see the power until the ice maker ask for water. Does the ice maker have ice remaining in the ice slots? If not then fill with tap water and after the water freezes and ice maker cycles dropping the ice into the ice bin if it does not refill with water then you will only need to change the=> 2315576 Water Inlet Valve If the ice maker does nothing you will need to change the ice maker=> 4317943 Ice Maker Assembly You can find trouble shooting info at Appliance 911
, Thanks John Tripp
Feb 19, 2014 | Maytag M1TXEMMWW (209 cu ft) Top Freezer...
How do I access the Ice Dispenser Motor?
Paul, On most refrigerators you would first pull out the bin where the ice is stored. Above that you will see the entire ice maker. First turn off the water and electricity. You will be able to remove the entire ice maker. Before I bought another motor, I would check on the price of a whole new unit. You'll sometimes find that it's not that much different than buying parts. It all goes by accessibility. You can go anywhere and buy an ice maker, but when you only want part of one, then it's a different story.
Nov 21, 2013 | Kenmore Refrigerators
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working. The water is cool, the filter is new. Dispensing water, but no ice.
It sounds like the solenoid valve has failed. This is what regulates the water to the ice maker. Have it replaced and that should take care of the problem. Hope this helps. Good luck.
Aug 10, 2009 | Whirlpool Gold® GC5NHAXSY
Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
Jun 05, 2009 | U-Line Refrigerator Ice Maker
Ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Apr 11, 2009 | Refrigerators
Kenmore side-by-side not ejecting ice
Did the ejector blades go around when you jumped it out? If they did not the the motor is probably gone and your going to have to replace the head of the ice maker or the whole ice maker. Check to see if home depot has a install kit for your brand. You'll probably pay less for the whole kit than the ice maker. But before you do turn the temperature down in the freezer.
Dec 02, 2008 | Kenmore Refrigerators
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
U-Line 95
The part number is #150 faceplate. This would be the motor and switches. Approx $55.00 Appliance parts depot would have it. Or try all brand parts.
Jun 07, 2008 | U-Line Icemaker
Refrigerators Logo
49 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
