Probably a broken belt. To replace it you must remove the drum. Start by removing the lint filter. and the 2 phillip screws in the lint filter cousing. Then use a flat blade putty knife to pop the top. Raise up the front and sit it out the way. Grab the drum and remove it. Oil the rollers with non flammable oil. I use zoom-oil. Vacuum out the dryer. The new belt will probably be a part# 341241. Ribbed side goes down on the drum. It is best to get a friend to hold the drum up so you can install the idler. The idler goes into the floor with the pulley to the left. Raise up the idler and insert the belt under the idler wheel and onto the motor pully. I have photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "thank you so much my dryer is working again, we could not have done it without your advice and pictures....thanks again...Barbara"
