Question about Vacuums
I have a Hoover Central Vac model S5673 and it stops periodically
I have a Hoover Central Vac model S5673 and it will stop at any time , I believe the reset overheats. Where can I get a new reset assembly that includes the electronic compoments? Thanks Larry
reddevil6
  • 1673 Answers
SOURCE: Valve Stem Assembly for Hoover Steam Vac
Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
Posted on Feb 14, 2008
reddevil6
  • 1673 Answers
SOURCE: valve stem assembly
reddevil6
  • 1673 Answers
SOURCE: Central vac (Hoover) always on!
There should be a manual/auto switch. If it is in the manual mode, then it will run all the time. Other then that you probably have a stuck relay. But this will have a years warranty on it, so you should be able to have it serviced under warranty.
Posted on Mar 06, 2008
VacuumRepair
  • 438 Answers
SOURCE: I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Posted on Mar 23, 2010
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
Low suction
I suspect the hoses are plugged with debris.
Apr 21, 2017 | Hoover L2310 GUV Central System Vacuum
I only used it once or twice and then the suction stopped and I can't figure out what went wrong. Hoover Steam Vac
This model has suction as soon as you turn on the machine. make sure the lower tank lid is on properly and the tank is latched in place. check the hose attachment door if that may be open. There is a float in the tank that will stop suction whenit is time to change the water, make sure the tank is empty.
Aug 06, 2009 | Hoover F7431-900 SteamVac Vacuum
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Eureka central vac 's power stopped won't start again.
I took to dealer I bought from . He examined it. The motor is gone needs new one. Thanks, Ann
Jan 24, 2009 | Eureka 1810 Central System Vacuum
Wireing up central vac too braker box.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=579196
Generic problem for all Vacuums
Wiring up central vac too
Posted by brneault on May 08, 2008
Wiring up central vac too breaker box.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
A central vac not knowing the brand name or model # uses regular household current and plugs into a regular household inlet and I have never heard of wiring the central vac to the breaker box. The central vac is usually out in the garage or down the basement and will be in the regular household current. You may want to ask the manufacturer or the vac dealer you purchased the central vac from and they might have more information for your and if your central vac needs to be wired to the breaker box they will give you instructions, but I don’t believe that you need to do so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 08, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Oct 08, 2007 | Hoover L2310 GUV Central System Vacuum
Vacuums Logo
152 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
