Question about Behringer Pmp3000 16 Channel Audio Mixer
Europower pmp 3000 120v or 220v ? - Behringer Pmp3000 16 Channel Audio Mixer
  • Behringer Master
  • 5,603 Answers
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Posted on Feb 06, 2010
  • Petrica Voicu Aug 16, 2015
    This is WRONG. There is a jumper (JP1). If you cut that jumper, the mixer will operate for 220V. This power supply is the same with the ones used in desktop computers. I did that to my mixer bought from US made for 110v. I replaced that jumper with a switch (from a desktop power supply), I made a whole and I fixed the switch on the pack panel of the mixer. So now, I can switch it manually for 110v or 220v. It's working perfectly. I tested it for long time and no problems. Good luck.
    PS. I called the Behringer technical support in the US and they weren't able to teach me that. So I figured it out myself after a big research. I'll try to upload some pictures about my project
  • Anonymous Mar 19, 2017
    Could you explain me where is the jumper? I bought pmp4000 in US and I want use it in 220v country. I appreciate if you do that.
It has 2 shorts on SMPSU29. One marked 110V should be removed and the second should be replaced from 110V point to 230V point. Thats all.
Posted on Sep 12, 2012
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Fuse blown on Europower PMP
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Posted on Jul 06, 2011
  • 5603 Answers
SOURCE: One side of my europower
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
Posted on Aug 18, 2011
I have my pc hooked via 1/8" to 1/4' to my europower pmp518m and my sound is very low, but my mics are very loud (need music loud also)
The 1/8 jackon the PC is Stereo so you would need a stereo splitter to then go into separate jacks or maybe tape input on the PMP. Plugging in a mono jack shorts out one side of the PC audio out. Make sure you use a splitter type and NOT a 1/8 to 1/4 stereo cable. It must split into TWO cablles to plug into the PMP.
Mar 12, 2013 | Music
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
Aug 28, 2011 | Behringer Pmp2000 Europower 800w 10ch...
One side of my europower pmp 5000 is out, the other is fine.....what up?
Aug 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
No sound from left side
Do you have the pan level shifted all the way to the right by any chance?
Feb 28, 2011 | Behringer Europower Pmp1000 Powered Mixer...
No amp output.amplifier damage
You will have to have it repaired. Also read my tip regarduing the PMP mixer/amps that if you use 1/4 inch cable plugs to speakers, the SLEEVE of channel A is hot, not the tip. It the sleeve shportss to somehing that is ground, goodbye Channel A or more. This is not in the book.
Feb 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
How do I turn on my europower pmp 2000
The power button (push) is in the back, just next to where you plug power cord.
Aug 06, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
522 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
