Question about Behringer Pmp3000 16 Channel Audio Mixer
Europowre pmp 3000 a120v or 220v? - Behringer Pmp3000 16 Channel Audio Mixer
  • 64 Answers
There is a jumper (JP1 or J1). If you cut that jumper, the mixer will operate for 220V. This power supply is the same with the ones used in desktop computers. I did that to my mixer bought from US made for 110v. I replaced that jumper with a switch (from a desktop power supply), I made a whole and I fixed the switch on the pack panel of the mixer. So now, I can switch it manually for 110v or 220v. It's working perfectly. I tested it for long time and no problems. Good luck.
PS. I called the Behringer technical support in the US and they weren't able to teach me that. So I figured it out myself after a big research. See the pictures about my project. :)
europowre pmp 3000 a120v or 220v? - europowre-pmp-3000-a120v-or-220v-vtnbpargg3dudya2e50g5p1t-1-0.jpg
Posted on Aug 11, 2015
  • Behringer Master
  • 5,603 Answers
The unit has a WIDE range power supply that will take 100 to 240 volts without changing anything.
Posted on Feb 06, 2010
  • Petrica Voicu Aug 11, 2015
    This is WRONG. There is a jumper (JP1). If you cut that jumper, the mixer will operate for 220V. This power supply is the same with the ones used in desktop computers. I did that to my mixer bought from US made for 110v. I replaced that jumper with a switch (from a desktop power supply), I made a whole and I fixed the switch on the pack panel of the mixer. So now, I can switch it manually for 110v or 220v. It's working perfectly. I tested it for long time and no problems. Good luck.
    PS. I called the Behringer technical support in the US and they weren't able to teach me that. So I figured it out myself after a big research. I'll try to upload some pictures about my project.
How do I get a schematic diagram for behringer europowr 2000
Try http://elektrotanya.com You can download 2 circuits per day for free, or pass an electronics test & create a login to get access to more.... Good Luck!
Dec 21, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
I have a ppm 3000 and one of the XLR outs quit working. Easy fix or not worth it? Everything else works fine. Suggestions for a replacement??
If it's really just the socket that's quit then it may be an easyish fix depending on which one. If it's worth fixing really depends on which XLR out had died and in what way. These were from the 'bad' behringer phase and are normally not worth fixing.
Sep 27, 2013 | Behringer PMP 3000 POWER MIXER
I have a PMP 3000 and 2 B212XL. I want to know how many more B212's or other speakers I can connect to the PMP3000. The current setup lacks power at the moment.
Absolute maximum is two of these per side. The speakers are 8 ohm and two on each of the outputs would be 4 ohms which is the minimum allowed for the amplifier. You will get about 400 Watts RMS per side doing this. Please note that the stated 1200 watts for the amp is the PEAK (fakey) values put forth in all the ads we get now. With 4 total B212XL's you should be able to fill an indoor venue of about 10000 square feet with sound at the OSHA limit.
Feb 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
PMP 5000 blows fuse at start up
for a 220v 50hz 1000w the fuse is T 6 3 AH 250v
for a 100v 1000w the fuse is T10 AH 250v just make sertun thats wright or contact the manufacture address 18912 north Greek Parkway, suite 200 bothell, WA 98011 USA phone +14256720816
Nov 28, 2011 | Behringer Music
We are trying to purchase a pmp mixer for our church choir. What's the difference between the pmp 3000 and the pmp 4000? Thanks!
The answer is "Not Much"... they upped the rating for power out and added 1000 to the model number... I don't know of any circuitry difference between them... it would probably be minor. Functionality is the same.
Oct 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Not enough sound, im using a pmp 3000 with rhino rh2112 250 watt speakers its up at max and struggling badly at very small venues
The speakers would receive about 250 watts max each from the PMP3000 since they are 8 ohms.
That is quite a bit and should fill a 1000 square foot venue with plenty of sound. The type of program material will affect what sound level you can get to. I would recommend you procure a sound meter and measure the sound level. You should be able to get 90 to 95 DB out of these easily. I use a PMP 3000 with two Peavey 15 inch with horn cabinets and can get 98 DB in a 30 by 40 foot room easily. You need to respect the OSHA sound level limits and a sound meter will help you comply. The 12 inch speakers would probably be too small if you are running a lot of bass through them. Please read my tip on Fixya regarding a hazard of the PMP mixers. Essentially, when using 1/4 inch adapters or plugs from the speakon connections of the PMP's, channel A sleeve or barrel is the hot whereas the tip of channel B is the hot. This is not documented in the user manual and if you inadvertenly ground the sleeve of channel A you will likely blow the amp.
Jun 27, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have a pmp 3000 and a pmp 6000. what is the best wast to run out of the boards to the speakers? and is it better to run in mono?
No preference, just use mode that fits your venue. As far as system safety I would run in Stereo A/B rather than bridged mode.
Now please read my tip about PMP units on Fixya regarding a hazard if you convert the Speakon outputs at some point to 1/4 inch plugs. If you do this, please note that the SLEEVE, not the tip on channel A is HOT to ground and shorting this to ground will often fry channel A. Channel "B" the tip is the hot speaker lead. Thsi is done by Behringer to facilitate switching to bridged mode.
Mar 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Electric scheme pmp 3000
Here: http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Scroll down to "get manual" and click to download. Ignore other links. Download is compressed file. You can decompress with the rar unzip for free...
Jan 20, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My behringer pmp 3000 has litle power i thing is 3000 or how much power it haveit? I put 2 speaker only ,,,, thankyou
The unit should drive 400 Watts RMS into a 4 ohm load per side.
The amount of sound power you get will VASTLY depend on speaker efficiency. You would likely use at least 15 inch speakers with the unit.
Aug 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Feb 05, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
194 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
