Question about Onkyo TX-8211 Receiver
I think i fried the power supply shorting against the chassis.. is it worth trying to fix it? touched bare speaker wire to chassis while it was on...
  • 4,234 Answers
Shorting the speaker wire to the chassis will present a zero(0) ohm load to the final amplification stage. The protection circuit won't have time to react and the output transistors are likely to be shorted. This is a common problem (shorted output transistors) and is easily repaired by a shop that handles audio gear. Expect a parts cost in the $16-$40 range.
Dan
Posted on Feb 05, 2010
  • 1,476 Answers
What leads you to think you fried the power supply in your unit? While touching the speaker wire to the chassis is never a good thing it should not have fried the power supply. Might have opened a fuse in the speaker circuit. Have you checked all the fuses yet? Try that first and get back to me and make sure the unit is unplugged before you open it up!!!
hardrocko
Hi I have a 05 ram 2500 hemi. I recently had a problem with my radio came out too be my accessories wire was fried. Well when this happened my info dome where mpgs are displayed my radio and blinkers all...
You either have a loose ground wire to the dash or a bare wire touching metal on a dash bracket or firewall that is loose. It seems more likely its the latter like the wire swings away from the dash at speed and lays back against a bracket or the firewall when you stop or go in reverse. Having a fried wire is a good indicator that there is a short somewhere possibly caused by a bare or frayed wire.
Feb 18, 2015 | Cars & Trucks
Arcam avr-250 shuts off?
New problem?
Did you move it recently? Sometimes the speaker wires are stripped too long and short out against each other in the back
Disconnect EVERYTHING from the unit but please take great care to document how everything is connected so you can connect it again the same way.
IF the unit powers on fine with everything dis-connected, I can assume that you have a connections problem with the speaker wires being the most likely culprit.
Make sure your speaker wires are not stripped too long where bare copper is touching other terminals OR make sure the speaker wire is pushed cleanly into the speaker connections without stray wires to cause a short.
Also make sure you have the speaker wires connected to the proper terminals and are not mis-wired into the wrong terminals.
IF it still shuts down after a few seconds with nothing connected then there is an internal problem that will need to be repaired.
Good luck.
May 28, 2014 | Audio Players & Recorders
When I turn on my kenwood it automatically turns off
First guess I have is you have speaker wires crossed or shorting out against each other, check your speaker wiring make sure no bare wires are touching each other, most amplifiers will automatically shut off if it senses a short. It doesn't specify, but i am taking a guess this is a amp/receiver
Jun 14, 2013 | Car Audio & Video
I have one of the power acoustik a2100d and it ceeps going into protection mode any suggestions will be greatfull thanks liam
This could be due to one of a couple things:
- Speaker wires shorting out against each other (or the speaker may be shorted out itself)
- Not enough current coming through the power wire (check power connection, ensure you are using big enough wire, i.e. 4awg)
- Not grounded well enough (check ground connection, make sure chassis ground is against bare metal and solid)
Mar 08, 2011 | Power Acoustik A2100D Car Audio Amplifier
My so31 ligths up but does not respond to remote
Check that the antenna isn't rubbing against the chassis as mine got rubbed thru and I think shorted the sensor. After trying playing with the left switch on the remote about 20-30 times it synced again with my chopper and I touched the open antenna wire purposely against the chasis and it would lose signal, then I removed it and it worked again. Tried that a few times so I think it's rubbing against something causing it to short out.
Jan 03, 2011 | xheli Syma S031 Outdoor RC Helicopter
When switch on power, the protect breaker shuts it down
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Feb 27, 2010 | Pyramid - PS52KX 40 Amp Power Supply Car...
The sound goes off and says "unprotected"
check speaker wire connections on the back of receiver
bare wires should never touch each other or the metal chassis
if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, firehazard and electric shock are the things we all want to avoid ;)
Sep 02, 2009 | Sony STR-DE685 Receiver
My amp turns on and off
Sounds like there could be a short somewhere. Check to make sure that there aren't any (exposed/bare) wires touching each other or if there is a bare spot of wire touching something metal. Check both ends of all the wires. A speaker wire may have come lose and is shorting out against the frame or some other place. Usually if it goes straight into protection mode or you're popping fuses you have a short somewhere. I assume the capacitor you installed is somewhere on the power line, which would be for helping with
noise. You can also try disconnecting your amp from your stereo and see what happens but leave the speakers connected, you don't want to run the amp with out a load on it (the speakers). If your amp doesn't go into protection mode when the stereo is disconnected, then you have a problem with the stereo and not the amp, assuming you already checked for any possible shorts first.
Jun 15, 2008 | Pyramid PB1236GX Car Audio Amplifier
Speaker Failure
search for a short to chassis when you mount the speaker,there's no problem if the magnet touch the chassis. you can test the cables with a multimeter.check if the tiny flexible cables on the speaker touch metal when is in movement. (on sound).
Sep 17, 2007 | Rockford Fosgate (P210D4) Car Subwoofer
My stereo is flashing the work "PROTECT" across the front
In a Kenwood deck, "PROTECT" usually means that one of the speaker output wires is shorted. The first thing to do is pull the deck and inspect the wiring at the back, making sure there aren't any pinched or exposed wires. If a speaker wire is pinched against the deck chassis, or bare wire is touching dash metal, it can cause your problem. If you don't see anything obvious, disconnect all speaker wires from the deck, then turn it on. If it still flashes "protect", then you have a defect in the unit. If not, then re-connect the speakers one at a time until you find the one that causes it to go into Protect mode. Usually if you don't find a pinched or shorted wire behind the radio, the problem can be found at the speaker itself. This is especially common if you've installed after-market speakers; if a speaker terminal connection has come loose and is now touching the speaker basket or mounting surface, it will shut down the deck.
Jun 07, 2007 | Kenwood KDC-MP5032 CD Player
Onkyo TX-8211 Receiver Logo
137 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
