Washing Machine may need fuse
Where is the fuse in a Maytag lat8204aae? I think changing it may solve my problem, but I can't find it.
  • blabbermouth Apr 20, 2008
    wont start cannot find fuse
  • Anonymous Feb 20, 2009
    what size fuse should be used in a washing machinee plus
    President:
  • Washing Mach... Master
  • 2,651 Answers
There is a fuse located in the lid switch (under the main top of the washing machine). I would reccomend replacing entire lid switch assy (part num22001682) $30 or so
Posted on Feb 21, 2008
  • 3 Answers
You can find the fuse in between the ac cord and the motor.
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
I have a maytag model A312 washer that has worked fine for almost 30 years. Wash cycle works with water pouring in but the barrel will not spin. I cannot even force it to spin around. Any suggestions...
Hello, Awesome Maytag washing machine. Sound like that wonderful Maytag transmission has finally gone to transmission retirement center. I think they might have rebuilt transmission for your Maytag washing machine. Check with your local Appliance Repair Shop---Maytag---. Ask them if they have a transmission but I am thinking here, it could be belt driven. If it is belt driven, empty the washing machine and be careful when turn over your washing machine. There is two concrete block that hangs on a self leveler to keep you washing balanced during the spin cycle.
Also, check for oil under your washing machine and if there oil then your washing machine has a transmission and it is leaking. Well, Tracy you can try the few thing that I mentioned here. But remember I am only suggesting you try these thing and if you don't fell like you can't handle it. Then get your neighbors and friends to help you, please. GB...stewbison
Sep 07, 2011 | Maytag Washing Machines
Timer on washing machine runs through it's cycle but the drive motor never runs. It fills with water but will not agitate or spin. Does not seem to want to drain either. This is a Maytag LAT9700AAW top...
The lid switch or the lid switch fuse may be bad.
Open the control console to check the switch and fuse located in the center of the machine,behind the control panel.
Also check the belts underneath to make sure they are not broken or stretched.
Apr 03, 2011 | Maytag Washing Machines
Start your wash machine
If your washer doesn't seem to work at all, check these: No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 01, 2010 | Maytag PAV2300 Top Load Washer
MAYTAG MAH5500BWW
No power
Lid switch
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Maytag washer is full of water and is dead
this washer has a 2 switch system for making sure the lid is closed. you wont be able to just "bypass" it as they designed it to not allow that. what you need to do is replace the whole switch assembly. it comes with both switches and a fuse all together and that should make your unit run again.
you can change this yourself but be careful to get the wires onto the new assembly n the right places.
Dec 28, 2008 | Maytag Atlantis MAV7551 Top Load Washer
Maytag top loader MAV 8000MWW
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Sep 27, 2008 | Maytag Atlantis MAV8000
Washing Machines Logo
974 people viewed this question
Top Washing Machines Experts
