Question about Pitney Bowes Office Equipment & Supplies
Pitney bowes imagistics modle dl370 with a trouble code of cof32
  • 168 Answers
SOURCE: Error Code
I think that is a Duplex error message. The duplex unit is not getting the correct power.
One thing you can try, is to slide the (ADU) duplex unit out and don't push it all the way in. Leave it out about an inch. Then turn the machine on and off. If the machine starts to warm up, but tells you to slide the duplex unit in, then you isolated the problem. Let me know if this works, and we can go from there.
Good luck.
Mac =)
Please always remember to post a feedback and a rating if I have helped you in anyway.
Posted on Feb 24, 2008
SOURCE: F2-02 Error on Imagistics ZB35 machine
You need to use Sharp genuine toner.There cartridges have a 'smart chip' on the rear of the cartridge.This error code is a direct result in fitting wrong toner.
Posted on Mar 03, 2009
  • 149 Answers
SOURCE: Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Posted on Feb 24, 2010
SOURCE: cof32 whats mean this code
f you are an end user and not a tech, you can correct your problem by replacing the "image unit" or "drum unit". You can use a refurbished one you can find easily on the net.
If the unit has gone the full life, you would want to put a new drum in with the developer. That would be the reason to suggest the whole unit. Good info to have would be the total page count and to know when, if ever , the last change was made. Without that info a tech can not make the correct decision.
Posted on May 25, 2010
Sharp AR-M237 had toner replaced and worked for about an hour before getting f2-02 error. When booting up the copier will display "Toner Replenishment in Progress." Then display shows the F2-02 error code.
Posted on Jun 19, 2013
Imagistics all in one copier/fax/scanner im2520f. All is working except the scanner which is giving error code EA21F7.
Try restarting your printer to see if the scanner lense moves properly and not jammed next you need to download the latest driver and suite from manufacturer`s website which shall definatly solve your problem.
Sep 30, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
96 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
