Question about Dishwashers
We have a taurus tds 52e dish washer it will work perfectley for 2 to 3 washes then keep tripping the trip switch leave for 2 to 3 days press the start button and it goes again
  • 76 Answers
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Posted on Jun 29, 2007
colin324
  • 57 Answers
SOURCE: washing machine
Sounds like you may have a corrosion issue or water ingress, causing a short. Could be a corroded heater, water in the main control board, water in the pump motor - the list is endless. Most washers tend to run the pump to ensure drum is drained before starting the cycle, so it would be probable that the problem is in the pump area.
You don't say if the main switch is an RCD or an ELB. I presume it's an RCD.
Posted on Nov 20, 2007
noffie
  • 10 Answers
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
Posted on Apr 08, 2008
SOURCE: my dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Posted on May 22, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Hi my fisher and paykel MW512 top loader washing machine keeps throwing my electrical switch. A few months ago it wouldnt drain and came up with heaps of error codes and now it is tripping my switch. What...
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
Mar 25, 2015 | Fisher and Paykel Washing Machines
Where is the trip meter reset button on a Lexus ES350
Hi there:
  • Turn the "Engine Start Stop" switch OFF with the trip meter A reading shown.
  • While pressing the trip meter reset button, set the "Engine Start Stop" switch to the Ignition ON mode. Continue to press and hold the button until the trip meter displays 000000.
  • Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using FixYa, have a nice day.
    Aug 21, 2012 | Lexus ES 350 Cars & Trucks
    My zanussi washer dryer keeps tripping the electrics
    check ground wire for tightness on plug in and on breaker box.
    Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
    Cycle switch keeps tripping
    Switch actuator (usually on washer lid) is probably broken if you can complete the cycle by depressing switch manually.
    Jan 17, 2012 | Amana 3.2 cu. ft. Top-Load Washer
    My washing machine keeps tripping the electrics everytime i switch it on, i have tried different sockets and the same thing happens. I have only had the washer 2 days and it was working fine, i got this...
    If its a new machine then call repairman under Warranty. If not then could be the Heater Element disconnect one side of the wiring to see if machine can run without blowing ELCB
    Jan 22, 2011 | Washing Machines
    Power overload swith in the house has started tripping when the dishwasher is started
    Is this happening only now! If it was working OK earlier and tripping now only it may be due to some electrical fault inside the machine.
    Switch off all the high power appliances and try the dish washer. If it works you have to check the breaker overall power rating!
    If it trips during dish washer ON, the fault could be in the heater circuit of your machine. Heater Insulation would have become weak etc.
    May 17, 2010 | Dishwashers
    Hotpoint aquarious wd 440 two years old tripping main board
    A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
    Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
    My hotpoint ultima keeps triping the trip switch. it had f08 on the screen but now that has gone, but still trips electrics every time i press start.
    Hi
    f08 means heater relay cannot be actived so try unplugging heater element and see if it stops tripping the electrics.
    regards
    Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
    Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
    Dishwashers Logo
    41 people viewed this question
    Top Dishwashers Experts
