Question about Pentair Minimax NT Heater
Pentair Minimax NT Heater, this AM, come on with a bang, blowing the metal cover off the cabinet. Possible problem{s}? Dave
  • 990 Answers
Rat nests inside the fire box or cloggs in the gas orface's going to the burners. Quite often this could be small spider webs that will look like lint.
If you have something keeping the gas from getting to the ignitor or the pilot instead of getting a smooth ignition the gas will build untill it reaches the ignition source, then boom. This will esaust all the oxigen and it will shut the heater down till it cycles again.
Hope this helps.
Posted on Feb 06, 2010
Testimonial: "Thank you, I have a technitian coming Monday. Fooling with gas is for experts only! Thanks for advice. Dave"
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Pentair minimax nt propane heater is blowing black smoke
is heater installed in a shed? how many btu's is your heater. You need 1 square inch per 1000 btu's for combustion air opening. Lack of combustion air will cause heater to under fire and produce carbon dioxide
Mar 16, 2014 | Pentair Minimax NT Heater
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
The VAC switch is probably no more good on my minimax pool heater. I have a new one but can't find where it is located. Any suggestions?
The air switch is located inside the front heater cabinet on the right hand side. You must remove both sheet metal boxes on the right to access this part. Just follow the rubber tube into the lower metal box.
NOTE: on these units, its much more common to see the rubber tubing fail. Not the actual air switch. To check the tubing, remove from the air switch, then remove the upper right panel to access the fan area. Follow the tubing into the fan casing and and remove. Check to make sure rubber is not brittle, crackes, or broken. Replace if necessary.
Sep 14, 2011 | Pentair Minimax NT Heater
I have a pentair minimax nt high altitude propane 4000000 btu in a commercial setting i run it 12 hrs a day is that too much?
Hope you are using lots of insulation. I have a bubble cover exposed during sunny days then put pool cover over at nite. Also have 4 x 8 ft Styrofoam pink insulation on top of the bubble cover. That costs $19 per sheet at Home Depot. 2" thick R 10.
Nov 07, 2010 | Pentair Minimax NT Heater
I have a Pentair MiniMax NT heater. The fan does
if voltage to fan replace capacitor if no voltage check safety circuit
Aug 16, 2017 | Pentair Minimax NT Heater
Error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
May 23, 2010 | Pentair Minimax NT Heater
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
No display lights
Make sure you have 24 volts coming from the transformer...Alot cheaper part.
Jun 01, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
147 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
