Question about Electrolux Dryers
I have the IQ Touch Electrolux washer and dryer and I have an E92 error code on the DRYER and wondering if this is easily fixable by the owner without calling a repair man. The E92 code is listed as the following : E92 FAULT= Incompatible protocol POSSIBLE FAULT CONDITION= Electronic Control Board incompatible with Interface Board POSSIBLE SOLUTION= Check if correct Interface Board console and Electronic Control Board are installed. Replace appropriate hardware.
Illeagle
  • 525 Answers
SOURCE: whirlpool duet dryer - PF error
Here are 2 good ones from very large inventory companies
http://www.apdepot.com/index.asp
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
SOURCE: Model MDE5500AYW Maytag Neptune Dryer showing code 8.8 and won's start
Look at this link... it worked for me!!! Basically,
1) Use a heating pad and warm the display.
2) Open the dryer door as well to let the warm air in.
It took about 15 min for me and saved me a over $100 in repair costs.
http://mikemerrittmotors.yuku.com/topic/796/t/Maytag-Neptune-Dryer-Lights-up-8-8-Wont-work.html
Posted on Jan 02, 2009
protek480
  • 1714 Answers
SOURCE: Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Posted on Jul 11, 2009
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
Ranglo
  • 1194 Answers
SOURCE: Dryer will not get hot. Is there something simple
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Select a heat setting other than Air Fluff.
Make sure gas supply is on for gas dryer, Clean the lint filter and exhaust duct.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 21, 2010
Where is the filter on tumble dryer AWZ241
Hi Angie, The filter is at the back right in the middle, You pull the cover off and clean off the lint.........CHEERS..
Apr 27, 2016 | Electrolux IQ-Touch EIMED55IIW 27"...
Why is the countdown timer not working?
Good Morning Ray, this is Z. Thank you for your question!
From what you have described it sounds like your Electrolux dryer may either have a communication error from the main control board or the timer itself may not be operating correctly. You can attempt resetting your dryer by unplugging it or flipping off the breaker for about ten minutes. If the problem still persists, it would be advisable to contact an experienced appliance repair tech to assist further.
May 18, 2014 | Electrolux EIMED55IIW 8-0 cu- ft- Electric...
I have an Electrolux EIFLSS55IIWO Washer. The chrome paint on the selector knob is chipping so Electrolux is sending me 2 new knobs for the washer and matching dryer. Can you please advise how to replace...
Good Morning David,
I see that you are looking to replace the selector knobs for your Electrolux washer, model# EIFLS55IIW as well as your matching dryer. This is typically not a common DIY job, and I do recommend contacting an authorized technician. However, I have found a link on the manufacturers sister website, which I have listed below, that provides a parts breakdown. It will also allow you to enter in the model number of your Electrolux dryer and locate the parts breakdown, as well as, a comprehensive listing of authorized techs in your area. Hope this proves to be helpful!
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=EIFLS55IIW0&User=&Search=Search
-Best Regards-
WP
Apr 07, 2014 | Electrolux EIFLS55IIW - Front Load Washer...
I have an Electrolux EWF 1083 - E90,E92,E94 come up can you tell me what is going on as it soesn't appear in the manual. I have had the machine for about 20 months. Regards Cheryl
It is a bad wire connection/control board fault causing poor communication. Remove the panel and inspect the back of the control board for corrosion,arcing and loose wiring.If nothing seems visible you may need to replace the board.Hope this helps
Jan 28, 2011 | Electrolux EIFLW55HIW Front Load Washer...
My washing machine and dryer is not working. Where
check the required voltage i think your voltage is different than usa it could be as simple a switch i would look on the back of the machine to see what voltage it operates on and call an electrolux dealer
Apr 12, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Dryer shows E63 error code? What is it? Should I call service?
The error code E63 is a high temperature warning
If you dryer is under warranty, take advantage of it. If not it may be a failing sensor or possibly a control board.
Apr 11, 2009 | Electrolux EIED55H Dryer
Electrolux ew 1280
Must be an Error Code, please refer to the owner manual
Thanks....!!!!
Jul 30, 2008 | Electrolux EW1209i Front Load Washer /...
Dryers Logo
180 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
