Question about Fahrenheat Built-In Baseboard Thermostat Heater
Will the thermostat shown above that comes with the baseboard heaters shut off when the room reaches that tempature level?
    Problem Solver:
  • 10 Answers
It should,but you should be sure by setting to desired temp and take a temp reading with a digital thermometer as close to the bulb as possible
Posted on Feb 06, 2010
Temperature control
Try this simple test
Turn the thermostat down to room temperature
If it turns off when you reach room temperature it means the thermostat is ok
Now if you place the thermostat back to 82 as you say you must have to leave it there until the warmth returns to the furnace thermostat
So it's either bloody cold were you are or your furnace is undersized
Dec 26, 2013 | Kitchen Ranges
Honeywell rlv430 is wired in correctly, yet one baseboard heater is always on, regardless of the temp Its set at
Need to start with comparing the temp in the room to the temp the heater is set to. A t-stat will read +/- the actual temp. If their not even close, then the heater will run trying to reach the temp the t-stat is set to.
Mar 06, 2011 | Honeywell Programmable Thermostat Heater
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Heater slow coming back on after having reached temperature.
lower the tempature setting so the residual heat is the right temp your looking for
Jun 20, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
How to size a room for baseboard.
HERE YOU GO CALCULATE THE HEAT @ 10 WATTS PER SQUARE FOOT , TAKE THE LENGTH X WIDTH X 10 AND THIS WILL TELL YOU THE AMOUNT OF WATTAGE YOU NEED . MOST ALL BASEBOARD HEATERS ARE RATED @ 250 WATTS PER LEN FT AS TO SAY A EX. A 4FT HEATER IS 1000 WATTS , MOST OF THE THERMOSTATS ARE RATED @ 20 AMPS AS IS THE 12-2-WG WIRE TO RUN TO HEATERS AND THERMOSTAT DIVIDE THE TOTAL WATTAGE BY THE LINE VOLTAGE USUALLY 240VOLT IN US .AND THIS WILL TELL YOU THE CURRENT DRAW ----WHICH CANNOT EXCEED 20 AMPS ON 12-3-WG AND THAT IS THE LIMIT OF THE THERMOSTAT AS WELL THESE STATES APPLY 99% OF THE TIME I DO REALIZE THERE ARE EX BUT HAVE USED THESE FORMULAS FOR 35 YEARS OF DOING MY WORK AND THEY DO FINE
Dec 16, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard heater
the stat points are stuck together or the stat is defective. try tapping on it to make them loosen up or replace the thermostat.
Dec 08, 2008 | Fahrenheat FBE15002 Baseboard Heater
Baseboard heater
Make sure BOTH fuses on each heater circuit test ok -- they are no doubt 220V -- hence 2 fuses
Nov 08, 2007 | Honeywell (CT62B1015) Baseboard Heater
Fahrenheat Built-In Baseboard Thermostat Heater Logo
97 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
