Question about MSI K8N Neo4-F Motherboard
Tower will not project to working monitor - MSI K8N Neo4-F Motherboard
My system suddeny restrting with more times one or two minits so solo this problam plz
Posted on Feb 06, 2010
What type of pc tower is compatible with an older gateway monitor model fpd1750
Try typing in, "compatible PC towers for gateway model fpd1750" on Google.
Jun 13, 2014 | Gateway FPD 1750 17" Flat Panel LCD...
My computer has recently decided to stop working. I can turn on the tower and the monitor to power it up and the tower does it's normal thing like it is working, the screen on the other hand stays...
If you mean you didn't get any display in your monitor the first solution is u must reinsert your memory and memory slot.if still have the same issue confirm your monitor is connected to your tower properly.if you still have the same issue just replace your memory (ram).thank you.
Sep 05, 2011 | Compaq Presario 5000 PC Desktop
The monitor keeps saying no signal
Turn power off to the tower and the monitor before making any connection changes.Make sure that the Blue connector from your monitor is connected to the Blue connector on the back of the computer tower. If this doesn't work you should try the monitor with another computer, just to check that the monitor is working. If the monitor works on another computer you may need to buy a Graphics Card. Next, try another monitor with your tower- If the problem still exists it is likely you need a Graphics Card.
Mar 19, 2011 | Acer Aspire X1300 (PV.SCC0X.002) PC...
How can i bypass the e-security feature on this monitor? i built a new tower and when i switched monitors. the monitor prompted me for a password...
install monitor on the last tower it worked on and then remove password or disable security feature. then move to new tower
Dec 15, 2010 | Gateway FPD2275W LCD Monitor
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
I have a HP 1703 monitor and it doesn't work with my Dell tower
Below is link to a page that has downloads, troubleshooting and manuals for the HP 1703 monitor.
http://h10025.www1.hp.com/ewfrf/wc/product?product=324213&lc=en&cc=us&dlc=en&lang=en&cc=us
I hope that you find this information helpful. You man need to install a HP 1703 driver on your computer for it to work.
If you do find this helpful, please leave positive feedback for me.
Thank You,
Brian
Jan 25, 2010 | Computers & Internet
Monitor keeps saying no signal.Tried a new cord from monitor to tower but that did not help.The light is on the monitor to show that it is on.Help please.
connect another working Monitor to the tower, if this solve the problem send in the monitor to the monitor's authorised repair center. If the problem is not solved, replace the Vedio card on the tower
Dec 28, 2009 | E-Machines eMachines Monitor E15T4
MSI K8N Neo4-F Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
