Question about Dell E173FP 17" LCD Monitor
MONITOR KEEPS GOING OFF.
THERE IS A LITTLE KNOB ON THE KEYBOARD TO THE RIGHT OF THE LOCK AND UNLOCK ICON ON THE MONITOR. The monitor keeps going off and pressing this knob brings it on however it is not working properly. The monitor stays on for a fraction of a second and goes off. If I keep pressing the button it eventually stays on for a short time. I had this trouble when I first got the machine and then it settled down and I had no more problems so I didnt report it but now it is doing it all the time. I can sometimes see the monitor for a few minutes like now and other times it goes dark although you can still type and see what you have typed when it lights up again. You can just about make out whats on the monitor in the dark so the actual computer is still on. What should I do. Can I stop this knob from going off?
Same as all else. I have a Dell 17" that keeps going off when first initiated. After about 12 to 18 times, turning off then on again, it seems to stay on but it takes longer and longer. Is this a problem with the monitor? or is it something with the computer? It has been suggested that it could be the back light....but I don't know how that works on an LCD flatscreen
    Novelist:
  • 138 Answers
Try your monitor with another computer. If it's still a problem. This is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After the monitor goes off, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 27, 2008
Lock icon and menu keeps appearing
Anonymous,
To unlock the monitor controls and get rid of the Lock, press and hold the monitor Menu button for 20 seconds. You can also try this.http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L.
Dell Social Media and Communities
Feb 28, 2015 | Dell E171FP
CAN NOT GET NUMBER LOCK TO SHOW ON MONITOR
There's a little led that lights up on the keyboard to show that Num lock is on. Why do you want to see it on the monitor? Are you using some kind of keyboard software on your monitor? What is your operating system? What is the name of the keyboard software you are using? Could really use a little more information. Maybe your particular keyboard software doesn't have a num lock feature because the numbers are always locked any way. Need more details.
Oct 29, 2014 | Computers & Internet
My sound is muted on my monitor
you should have a button on the monitor to pop up a menu which will let u adjust the volume, also in the lower right hand corner of your computer screen look for an icon that looks like a speaker, right click this and you can adjust volume here or unmute, it maybe hidden and you may need to click the little arrow to reveal the speaker icon. Failing this go to Start Menu, Control Panel, Audio/Sound and find it here.
Dec 23, 2013 | Computers & Internet
How do I 'unlock' the lock icon on the keyboard?..it won't go off
Push which ever key applies to you, one of the following:
Num Lock
Caps Lock
Scroll Lock
By pushing one of the above keys the lights on the top right of the keyboard should go on and off. On means the lock is activated.
If there is still no response from the keyboard after pushing the key, it is possible that the membrane is damaged. Therefore your keyboard needs to be replaced.
Thanks and keep well!
damnor01
Apr 16, 2011 | Compaq Keyboard
I have a Dell Vostro and would like to lock the laptop and use a monitor and wireless keyboard whilst at home. Can you tell me if and how I can do this?
This is assuming you are using Windows 7. (Since you didn't specify. -_-)
Software lock at same time = No. Hardware lock at same time = Yes.
When you have the keyboard connect and the laptop plugged into the monitor, go to your Windows Mobility Center. Go to "Power Options. Look for "What to do when you close the lid." and tell it to do "Nothing".
Then close your laptop and lock it.
Viola.
Mar 24, 2011 | Dell VOSTRO 3500 Notebook
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
How do I lock my keyboard while a program is running?
well you can do this by using the filter keys ..follow the steps below to get your job done:
To lock keyboard with filterkeys ->activate sticky keys by pressing the shift key 5 times.
-> Go to settings and click the radio button 'use filter keys' this locks the keyboard and gives nifty little sounds all except the taskbar button if keyboard has one
->. easily unlock by double clicking little clock emblem in the bottom right hand corner of screen and deselecting use filter keys. Make sure you hit 'apply'
good luck ....i'm sure this works
Apr 08, 2010 | Microsoft Windows Vista Home Basic for PC
The keyboard is locked, is there an unlock code?
Try this
To lock keyboard with filterkeys activate sticky keys by pressing the shift key 5 times. Go to settings and click the radio button 'use filter keys' this locks the keyboard and gives nifty little sounds all except the taskbar button if keyboard has one. easily unlock by double clicking little clock emblem in the bottom right hand corner of screen and deselecting use filter keys. Make sure you hit 'apply'
Dec 04, 2009 | HP Compaq Presario CQ60Z Notebook
How do you unlock the numlock on a gateway laptop?
Uncle Buck:
On the bottom of the keyboard and to the left you will see a blue "FN" .
Now locate the "Pad Lock or Key with a Paddle-lock Icon" across the top and to the right of the function keys.
Hold down the "FN" key, press the "pad Lock" key, release both keys.
You should be good to go...
Uncle bobby
Jun 04, 2009 | Gateway 2520915 Keyboard
Mystery icon on Dell Keyboard Model SK 8115
The icon should mean the NUM LOCK is on. All that does is activate the numberpad on the right side of the keyboard. Chances are the monitor's backlight is bad. Try another monitor. You can also get a flashlight, turn it on and hold it very close to the face of the screen. Look closely at the screen, can you see your desktop or login screen? If so the backlight is not working with in the monitor.
Jun 01, 2017 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Dell E173FP 17" LCD Monitor Logo
141 people viewed this question
Alun Cox
