Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I changed my rear turn signals on my 02 Sportster to the baby bullets from JP Cycles. They are wired correctly and are incandescent not led. Here is the problem, the signals work properly when the ignition is turned on, but when the bike is turned over and running the signals come on but stay steady on. They do not blink. I have changed the flasher unit, and now I am lost because this did not fix the problem. Where should I go now?
  • 116 Answers
I cant say for sure what but one thing is sure it is a wireing problem go over it again possible ground issue
Posted on Feb 11, 2010
How do I get to the wire housing on the rear of the 2008 Yamaha V Star 1100 Custom to switch from standard turn signals to LED bullets?
Im not completely familiar with that bike but from pictures and microfiche it looks like there are a couple of bolts under the fairing that when taken out shoild allow you to get into the wiring when you pull the cover out. I hope this helps
Dec 03, 2014 | 2008 Yamaha V Star 1100 Custom
How to install turn signals on a 1999 HD Wide Glide
If it has wiring in place to power the lights and mounting locations, go buy some turn signal lights that will look good and fit the mounts you have. Connect the brighter colors from the bike wiring to the brighter colors of the turn signals and the same for darker colors.
If you buy signals with LED lighis, buy a 12 Volt turn signal flasher that is made for LED's--eBay has them. If you choose turn signals with incandescent bulbs (the traditional type), be sure each bulb draws 16 or 17 watts as other wattages will not allow a standard flasher to operate correctly--google the bulb number to find out. With other bulb wattages, the signals won't flash; they will stay on or not turn on at all as standard flashers are made to drive 2 16-watt bulbs; 32 watt loads. The good news is that the flashers made for LEDs will work with any type of bulbs or LED's, so go ahead and order one of the LED flashers to avoid trouble shooting the signals once they are installed.
Apr 28, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
How to hook up a 2 wire system to a 3 wire system, help!
The 3 wire is a running light/turn signal combo. On the three wire you have neutral, turn sig hot and running light hot.
If you want the two wire bullet light to be a turn sig, you will have to hook up the neutral/ ground and the turn sig hot. The running light hot will be capped.
If you want the bullet light to be both a turn sig and a running light you will have to buy an aftermarket product to regulate the power to the lights.
Apr 14, 2014 | 1993 Harley Davidson XLH Sportster 883...
HAVE 2001 Sportster 883 SPORTSTER XLH, added a LED light to the sissy bar, rear turn signal a breaks really bright. Back lights quit working removed the LED. Still no rear brake light or turn signals,
Hi V-twin, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Jul 17, 2012 | 2000 Harley Davidson XL 1200 S Sportster...
My Turn Led Signal Can Not Blink
The LED lamps are not plug-in replacements for incandescent ones because they place a much lower load on the flasher.
Mar 07, 2017 | 1994 Mercedes-Benz C-Class
Good evening there..!i have a 1999 883cc sportster and i took of the original turn signals and i used a pair of lower swing arm turn signals/marker lights for rear and a pair of small bullet turn...
I know absolutely nothing about the Badlands turn signal units. My suggestion is to forward your question to them as it's one of their units that you have question about. I hope they can give you answers. I sorry that I can't help you.
http://www.badlandsmotorcycleproducts.com/Tech-Pages/Tech-Info-on-Electronic-Modules.htm
Good Luck
Steve
Sep 07, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
Changed the blinker lightbulbs on my 2000 Sportster but now they wont work front or back. Help???
The turn signal cancelling unit is designed to work with a specific load on it. You must use the proper bulbs for it to work. If you installed LED bulbs, the load is different. You can get a "load equallizer" that will allow you to run the LED bulbs but make sure you get the correct one and wire it in properly. Look here. http://www.badlandsmotorcycleproducts.com/Tech-Pages/WHICH-LOAD-SHOULD-I-USE.htm
Good Luck
Steve
Mar 01, 2011 | 2000 Harley Davidson XL Sportster 883
I want to change rear turn signal to led turn signal
They make LED bulbs so you don't have to replace the entire signal assembly
Sep 25, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Replacing signal lights on a 1992 sportster that has 2 wires on the original lighting to a bullet style turn signal that has 3 wires.
The two wire system is for a turn signal only unit. The three wire unit has a turn signal and a running light in it. Remove the turn signal lense and you'll probably see a dual filament bulb. The two wire system is shown as an "International" wired model according to my book. One wire is the "hot" wire (Brown) and the other is a ground or earth wire (black) on the bike. On the turn signal unit, probably all wires are black. You can use a VOM to determine which wire is the ground wire or you can just try hooking them up in different ways until you find one that works.
May 14, 2009 | 1993 Harley Davidson XLH Sportster 883
New drag bars for a '08 XL1200 Custom
jp cycles usa do a narrow drag bar that looks good ,
Mar 06, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
147 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
