Question about Briel Sintra ED-132 Espresso & Coffee Maker
Unit is 5 years old and the espresso grounds holder has become VERY difficult to align and insert up into the machine.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
After 5 years, the plastic has become warped by the heat of being used. The warpage could be in the holder, in the slot it slides into, or, most likely, both. If you can't handle the difficulty, then it is time to replace the unit. Actually, 5 years on any appliance is darn good service.
Posted on Feb 07, 2010
Keurig handle wont raise or lower it is stuck in the halfway position
Check for obstructions behind the machine, in the area behind the handle and in the area behind the kcup holder. Ensure that the kcup holder is inserted correctly, aligning the arrows at the top. Be careful of the needles!
Apr 06, 2014 | Keurig Elite B40 Coffee Maker
I have the Krups 964 espresso maker; it is about 10 years old. Recently it began to pour water out and around the coffee basket holder at a fast pace, and it does not make expresso. I did remove the...
I don't know much about this unit, but there might be a rubber seal in head where the porta filter locks in to. It is possible that this seal is either damaged or just corrupted with grounds. Try cleaning it out and or checking the seal for damage.
Sep 10, 2011 | Coffee Makers & Espresso Machines
My new Classic made perfect coffee for the first three weeks but now it sprays hot coffee in all directions from the delivery spout
Do you mean the spout OR do you mean the filter holder.If it sprays out too quickly from the outlet,it could be because the coffee is too dry, too coarsely ground or not compressed firmly enough in the filter. If it is spraying from around the filter holder it is probably old coffee grounds stuck on the rubber seal in the filter holder head (the part of the machine that the filter holder attaches to ) You can buy a special right angled brush for cleaning the rubber seal in place OR you can fold a washup sponge and use the corner to clean around the seal.
Jan 23, 2011 | Gaggia Classic Espresso Machine
I can't get the water to come through the coffee holder. It builds up pressure but won't shoot the coffee out. The water comes out if I take the holder off , but not when it is in place. Do I need a new...
Remove the brew head. Pry out the metal coffee filter, then pry out the rubber gasket. There is a small black plastic insert that is likely gunked up with coffee buildup. Clean the parts well, reassemble, and then try again.
If you are a good "tamper", you can leave out the rubber gasket and plastic insert entirely, and just go with the the filter. It takes a bit of practice, but you will get equally good crema if you match the grind to your tamp pressure.
Jun 21, 2010 | Saeco Starbucks Sirena Espresso Machine
How do I fix a leak from the coffee holder unit
Does it leak around the pod holder, or after the holder is removed?
It it is around then you need to replace the head gasket.
If it is after then the solenoid or the valve seat is damaged.
May 01, 2010 | Breville ESP8XL Espresso Machine
Saeco incanto deluxe gear or splinbe drive out 180 degrees.
Thats a tough one without seeing the unit, use the pic below to help align the unit.5101bd5.jpg
May 31, 2009 | Saeco Incanto Classic Espresso Machine
Half of the time, espresso leaks (or sprays) out of multiple points on the handle/portafilter, instead of coming out of the two designated holes. Almost as if too much pressure builds so it gets forced out...
Try running water only and see if you get the same result. If you do, then soak the filters and the bottom of the metal basket of the portafilter holder in vinegar (distilled white). In my experience, this unit requires constant cleaning. But the espresso is good.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart EM-200 Espresso Machine
My solis 5000 is making a grinding sound and I have tried to reset the machine with no succes
Sometimes the grinder has grounds "jamed" in the coffee grinder outlet. First, while grinding try turning the "quantity dial" (has + and - on dial inside coffee bean holder) back and forth to see if that breaks the coffee loose. Next, Use a small brush to clean the coffee grounds channel inside the machine. To do this, remove the brewing section, liquid tray, and spend grounds holder. On upper portion of machine, just above the area where the brewing unit is a small "trap door" where coffee grounds are delivered to the brewing unit. slip the "trap door" open (it's spring loaded so you will need to hold it open) and with a small brush gently brush the accumulated grounds out of the channel. (There may be a large accumulation of grounds if you are using dark roasted "oily" coffee. Good luck! hope this works for you
Jan 05, 2009 | Solis Master 5000 Espresso Machine
Gusto- water leaks over the grounds instead of filtering through
The holes in the metal coffee ground holder/filter are probably clogged. I have had this happen and it has cleared when I cleaned the holes in the coffee holder. I used the cut off head of a toothbrush and pushed the bristles through the holes. If you hold the filter to the light before and after cleaning, you can see the change in the proportion of closed holes.
Dec 01, 2008 | Krups Gusto 880-42 Espresso Machine
Breville Die Cast 800ESXL
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Feb 17, 2008 | Breville Die Cast 800ESXL Espresso Machine
Briel Sintra ED-132 Espresso & Coffee Maker Logo
47 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
