Question about MyMusix PD-201 MP3 Player
How do i format my MyMusix player - MyMusix PD-201 MP3 Player
  • 6,993 Answers
insert the player into the computer and wait for your computer to recognize and install your player respectively. After that, go to "My Computer" icon and double click from your desktop. You will find a drive representing your Player. Right click on the drive and you will see format.
Take care
Posted on Feb 05, 2010
Bagaiman acara memasukan lagu ciptaan sendiri ke you tube?
Posted on Feb 22, 2011
Reformat internal media as FAT16
Go to the Mymusix website and download the player update utility (located here: http://mymusix.mmvoice.com/products/audio/PD-6070/software.html )
install it, then use these instructions http://mymusix.mmvoice.com/products/audio/PD-6070/PD6070Vistaonlyfaq.html Starting at step 9.
I never got it to actually complete the update process, but it did format it, which solved the problem.
Oct 25, 2009 | MyMusix Audio Players & Recorders
Error-reformat intenal media as fat 16 this is all i get
Remove battery. Plug in computer. When drive opens up, Format drive as you would a CDRW. When format is done you should be able to reload MP3 files. Good luck
Oct 25, 2009 | MyMusix PD-6070 MP3 Player
My mp3 player cannot be reformatted
@ lady_virienn
Go to the Mymusix website and download the player update utility(located here:http://mymusix.mmvoice.com/products/audio/PD-6070/software.html )
install it, then use these instructionshttp://mymusix.mmvoice.com/products/audio/PD-6070/PD6070Vistaonlyfaq.html
Starting at step 9.
c@rl
Oct 17, 2009 | Audio Players & Recorders
Reformating the internal media to fat16,how?
install it, then use these instructions, but start at step 9. http://mymusix.mmvoice.com/products/audio/PD-6070/PD6070Vistaonlyfaq.html
I never got it to actually complete the update process, but it did format it, which solves the problem. Hope this helps
c@rl
Aug 09, 2009 | MyMusix PD-6070 MP3 Player
PD-6030 MyMusix problem
It could be a hardware issue, but you should at least try reformatting the player: There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 01, 2008 | MyMusix PD-6030 MP3 Player
Flash error please back up the data and format disk
Reformat the player.
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
May 05, 2008 | MyMusix PD-6030 MP3 Player
MY MP3 IS SAYING ERROR REFORMAT INTENAL MEDIA AS FAT16.
you neeed to go to my computer and right click on the Mp3 and click format, if you don't your Mp3 will just stop working that is what happend to me
Apr 04, 2008 | MyMusix PD-6070 MP3 Player
My mp3 won't come on
i got the exact same problem, i press the on button, and it says "MyMusix" for a long time then stops, when i put it in the comp. is says: DO NOT DISCONNECT! and now even more recently it wont do anything at all
Mar 28, 2008 | MyMusix PD-6070 MP3 Player
MyMusix PD-6030 MP3
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
You may also want to check www.mymusix.com for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Feb 12, 2008 | MyMusix PD-6030 MP3 Player
MyMusix PD-6110 MP3 Player
When you hook it up, you should see an icon on your computer for the MP3 player.
I download songs from iTunes to my MAC, then drag them to the MP3 player. However, they do not come from i'Tunes in a MP3 format. I found this on the internet for how to change the format:
When iTunes is open, find "preferences" and then locate "importing" (just look around on the different tabs till you find these, since Mac and Windows put them in different spots) tell it to import using MP3 encoder from the drop down bars, and say OK. now you can right click on the song you want to convert and select "convert to mp3".
Then drag the MP3 song to the MYMusix player icon and it should copy the song.
Dec 26, 2007 | MyMusix PD-6070 MP3 Player
MyMusix PD-201 MP3 Player Logo
253 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
