Question about Exercise & Fitness
Power Cord was damaged in transit. Replace or Repair? Replace-How
Nordic Track Model C 1800 - Power cord was cut when moving. How do you replace the power cord? Or, can you just splice it back together?
  • 79 Answers
You can only try to repair the section where they cut short and re-unite each with its respective color tape and you put him ready
Posted on Feb 06, 2010
Testimonial: "Thank you for reassuring me I was about to do the right thing. I had a terrible feeling this was not to be done this way, but it is the easiest fix. "
How to replace a power cord for a hoover vacuum?
Please add the specific model number, for example, Hoover vacuum, ECOVAC 497A.
Is this a wrap up power cord where you wrap it around two lugs on the vacuum, or is it a rewind type where the cord is wound inside the body of the vacuum?
Cheers.
Aug 15, 2014 | Vacuums
Replace main control board
Is the wall receptacle defective? Have you plugged something else into the same wall receptacle without circuit breaker activating? Test with another appliance that also has the third round ground prong. If this is not the problem then yes an electrical short exists within the treadmill, inspect the cord itself for loose prongs, there may be liquid damage inside from a previous liquid spillage which would cause an electrical short.
Dec 22, 2013 | Nordic Track Exercise & Fitness
Nordic Track treadmill A2105 will shut down and trip my HOME breaker while in use, what could be the problem? I have tried lubricating the belt and it worked a little longer than usual, but after abo
1) you must LUBE THE DECK BELT+ ROLLER BEARING.
2) Test the input voltage motor, if there are the MOTOR is faulty need REPAIR.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) SEE THE BLOCK DIAGRAM, whatever component can be faulty.
However you must test the power cord for short circuit between cable, repair, and look inside according the BLOCK, and proceed with logic, see any loose wires, or some wires touching the carcase, some filter, coil, power supply USE the VOM.
God bless you
May 27, 2012 | Nordic Track Exercise & Fitness
Does a nordic track commercial 1500 have a fuse?
see my personal TIPS specially block diagram, if you will see the fuse for every treadmills.
2) Reset the c.breaker too.
3) Reset the c.breaker from your house outlet wall.
4) Test the power cord for wires, break, loose, or burn and repair.
5) Test the power switch, for open or shor. see the diagram attached.
sincerely. God bless you
May 08, 2012 | Nordic Track NordicTrack Commercial 1500...
I just put my tread mill together Nordic Track A2550 and the belt wont move
1) test your circuit breaker home,reset
2)test the outlet for 115 vac
3)test the power cord if some wires is loose or cutting
4)reset your circuit breaker insider from your equipment
5)Eliminate any extension cord from your treadmill.
6)Be shure if the receptacle have ground cable with your divided TRSS.
sincerely.
ERNESTO CUADRA
MANAGUA,NICARAGUA. C.A.
Dec 11, 2011 | Nordic Track NordicTrack A2550 PRO...
I have a norty track C2500 an the screen went blank
I suggest checking your power plug then check or reset the circuit breaker on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 25, 2010 | Nordic Track Exercise & Fitness
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
10'' Sears MITER saw cord nick cut 1/3 way through 1 copper wire.
as long as the wires are intact it is still double grounded and yes you can replace the cord, as to not working sounds like a wire is broken
Mar 15, 2009 | Saws
Exercise & Fitness Logo
149 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
