Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
Comes on for about five seconds and then goes dark
When I boot the pc the monitor turns on for about five seconds and then it goes dark. If I shut down the monitor and turn it back on it does the same thing...comes on for about five seconds and then goes dark.
  • 3 more comments
  • Anonymous Feb 21, 2008
    Monitor comes on just long enough to glimpse screen content and goes dark again. I connected a different lcd monitor to the computer using same power and video cords and did not experience the problem. I connected the problem monitor to a different computer but the problem persisted.
  • shadystyle Feb 22, 2008
    i have the same monitor with the same problem.
  • BlindTiger May 14, 2008
    I had the same problem. Monitor would go dark after short time.
    Opened up the screen (use this link, http://www.wizardanswers.com/liquidvideo... as a guide) and
    found a bulging capacitor. Removed and installed new capacitor (Radio
    Shack $1.50). And easy peezy, it works swell.
  • cincee Oct 15, 2008
    When I turn on my computer the monitor screen comes on then goes black. If I turn it off then on again it will again come on for a few seconds. Not long enough though to view anything. Whats the fix for this anyone?
  • Brenda Kent Nov 11, 2008
    last night computer worked fine. THis morning when I turned it on the monitor stays on 1-3 seconds I heard a sound (like a bubble popping) then monitor goes black, then keeps repeating the same thing. When I did a restart it does the same thing. My monitor is 4-5 years old, I would think it would last longer than that as I paid about $400 for just the monitor.I cant see screen long enough to locate my mouse curser to even get to the help screen. Please help..............
I did as others have suggested, but with a twist. I not only replaced the fried C922 capacitor but one adjacent to it, and my monitor now works perfectly. Sorry, forgot the number of the other capacitor but it might not matter because it probably could've been almost any other one...I just happened to also spot the 2nd bad one (which I also replaced with another of higher voltage).
So, if you're going to go through all the trouble of opening the unit up to potentially replace one capacitor, be sure to inspect them all because there might be others.
Posted on Oct 17, 2008
I had the same problem with Capacitor C922. Just replaced it with a 35v, and now the monitor just blips on and off constantly (the power light goes on and off). There are other listings for this problem on this site, but no answers it seems...
Posted on Sep 30, 2008
The problem for me was that Capacitor number C922 has blown on the inverter board. It's an easy fix, just pop off the old one and solder on another with a higher voltage rating. The original cap was 1000uF and 15v i replaced it with a 1000uF 35v capacitor. it works great!
Posted on May 27, 2008
  • 83 Answers
MAKE SURE THE CONNECTION BETWEEN YOUR MONITOR AND YOUR COMPUTER IS PLUGGED IN TIGHTLY AND CORRECTLY, YOU MIGHT NEED A NEW POWER CABLE OR A NEW CABLE THAT CONNECTS FROM YOUR MONITOR TO YOUR COMPUTER, TRY CONNECTING YOUR MONITOR ON ITS OWN PLUG, OR IN ANOTHER SOCKET AROUND THE HOUSE IT MIGHT NOT BE GETTING ENOGH POWER, IF IT IS NOT LCD MONITOR (NOT FLAT) THEN YOUR COMPUTERS BULB MIGHT CIRCUT WRONG
Posted on Feb 21, 2008
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from mouser.com.
Mar 30, 2013 | Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Our monitor just recently stop working correct. It is on fine during boot but once Windows starts up, the screen goes dark after about 2 seconds. If you turn it off and back on, we get a screen again for...
try reinstalling the os.
there might be file corrupted in the system folder,,,
since the monitor runs on start up , we cannot say that it has a hardware defect...
reinstalling or upgrading your windows will help..
Mar 11, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
Once the PC is booted up the monito screen goes dark
try another monitor to isolate if it is the monitor, if it is the LCD, the back light may be going out
Jul 07, 2009 | Computers & Internet
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
HP 1702 Monitor comes on but immediately goes off.
There are five capacitors on the power board which have dried out and need replacement. A reputable repair shop should be able to fix this for around $50.00 including labor.
Mar 23, 2009 | Computers & Internet
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Monitor will ower up but no picture. If I shut monitor off and turn back on picture comes up for about a second and then goes black again. I really donw't wnat to buy a new one as this one is only 2...
is there a light on at the power button on your monitor...if not then there is a problem with the power cord but if the light is on then it could either be your monitor sttings are set to dark or you connection cord is faulty
Sep 10, 2008 | Computers & Internet
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
462 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
