Question about Dryers
I have absolutely no heat in my dryer...it's 20 years old...
  • Dryers Master
  • 8,404 Answers
Electric or gas?
The electric heater element may be finished, you will have to remove the back to determine. Of course, unplug the device before you perform any tests.
Gas? Might be as simple as a clogged orifice. Does yours have a pilot light? Is it burning? If not, is the Igniter functioning?
Might it be that the cat set your control to "air only' setting?
Replacement parts available from the manufacturer or www.FixYa.com advertiser or www.repairclinic.com
Thanks for your question at FixYa.com
Posted on Feb 05, 2010
Our dryer is a little over a year old. Everything seems like its running ok except for the fact that there is absolutely no heat. Any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | LG DLE2512W Electric Dryer
I need an answer please. why does my dryer tumbles but there is not heat. dryer 10 years old, should i replace or repair? thank you!
There is a common part that goes out after a decade on most dryers and it is called a "solenoid" which activates the heating function and turns heat on and off according to the setting you've commanded. The thermostat controls the degree and temp of heat, but when/if the solenoid fails ($20 part) there is NO HEAT that occurs. Dryers are very simple devices, hardly need replacing EVER, but with a repairman's help you should not have to spend much to get your machine working for another 10 years! Call a local repairman for the good news and have him fix it for you.
Oct 08, 2010 | Dryers
My dryer still heats, but the drum doesn't move. Is this going to be a costly repair, the dryer is about 20 years old and this is the first problem I'm ever had with it.
If you got 20 years out of your unit I would definitely keep it! You need a new drum belt. You can get it at http://www.repairclinic.com . They also have videos which show how to install the part. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
May 09, 2010 | Maytag Dryers
The drum turns but there is no heat
Get a new heating element if you wish your machine to continue performing.
Apr 18, 2010 | GE Profile DPSB620ECWW Electric Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
