Question about Samsung HLR5667W 56" Rear Projection HDTV
Left corner of the screen is dimmed out like bulb not aimed right
Picture is clear on the screen except for 2 inches vertically starting on the left side of the screen, it appears greyed out or darker with the picture dimmed behind it.
  • 1 more comment
  • drccampbell Feb 05, 2010
    Can an owner just buy and replace the light engine completely and not have a technician do it, or do I need to bite the bullet and pay a technician to fix it?
    Need to ask another question.
    Thanks, I appreciate your help!
  • Samsung Master
  • 19,396 Answers
Hi.
Your TV works projecting the light from the internal lamp on the screen. Before reaching the screen , the light will pass through a 'pipe' whose internal surface is covered in rectangular mirrors, located all over the tunnel surface.
A quite common fault is caused by one of the mirror detaching from the internal surface of the light tunnel, and falling down or hanging in there. This will be seen on the display as a darker shade located near to one side of the screen.
The light tunnel is located in the light engine. To repair the problem the TV must be disassembled by a technician. Accessing and disassembling the light engine is not a repair that can be done by the owner.
Click here to view pictures of the light engine for this model. The tunnel is the optical device visible on the engine.
Posted on Feb 05, 2010
  • Ginko
    Ginko Feb 05, 2010
    Yes the owner can replace the whole light engine, but that would not be the wisest choice.
    The light engine is worth between $500 and $1000, and it is very sensitive and easy to damage. The best thing to do under normal conditions is replacing the light tunnel, a technician will ask about $ 120/$200 to do the job, plus part (about $50).
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
How to adjust UK headlights in jeep grand cherokee 99-04? Can one adjust lences to meet european standards?
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
The lenses themselves cannot be adjusted to conform between left hand and right hand drive. The reflector or projector of a left hand drive vehicle is designed to throw more light towards the right side of the vehicle and vice versa for right hand drive vehicles.
Sep 15, 2009 | 2004 Jeep Grand Cherokee
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
How do you adjust the headlights on a 2006 dodge ram 2500 ?
Jul 28, 2009 | Dodge Ram 2500 Cars & Trucks
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Samsung HLR5667W 56" Rear Projection HDTV Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
