Question about Philips Magnavox 9P6034C 60" Rear Projection Television
When I turn the tv on, it is a very small bubble picture
I turn the tv on and the picture is in a very small bubble. After the tv warms up, it eventually goes to full screen. How can I fix this? Or do I need to junk it?
  • Valerie1055 Mar 05, 2008
    Please help!! My tv will play and then it will get small and then large. It's a continuation. It will show very small and then back to the average size. Please let me know if it's my Circuit Board and if so how much will that cost me.
  • Philips Master
  • 3,459 Answers
You can get a complete set of instructions and a parts kit from here. http://www.magnavoxhelp.com
Posted on Jun 20, 2008
  • Philips Master
  • 8,617 Answers
OPTO COUPLER Cost 6.99 if that doesnt do it then its power supply issues.
Posted on Mar 07, 2008
What is the best way to bleed air out of my cooling system on a 1994 BMW 318I
Warm car up to normal temp and next to cap on radiator is a small black plastic screw. Slowly loosen it (not all the way out) you'll hear air and see bubbles. When bubbles stop and a small amount of coolant is coming out, tighten it back up and you're done. You have to do this with car running and warm.
Jan 05, 2011 | BMW 318 Cars & Trucks
TV picture is unstable until the TV warms up. This is taking longer and longer. Picture gets large, small, large, small... Quality is also lacking until it is warmed up. This is a Phillips 60'' Is this...
What model and brand is your television?
Is it a CRT type or DLP?
If picture is getting smaller then larger, and its a crt rear projection television sound like you have bad connections around the Flyback transformer and or horizontal circuits. This usually happens when a connection is made on the circuit board and the picture returns to normal especially during a cold start, but as the television warms up the connections on the board start to seperate and the problem starts occuring or it could be in the reverse process. Unstable at first then when tv gets warm it make better connections. All in all have a technician check the HV section of your deflection board.
Sep 29, 2009 | Televison & Video
White bubbles & dead pixel on my tv
This seems to be an issue with your DMD board, that's why you're seeing thosed bubbles and pixels
Jul 30, 2009 | Samsung Televison & Video
60'' phillips pro
Easy fix....Goto www.TvRepairKits.com and get a chip kit.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
