Question about Canon T70 35mm SLR Camera
Need the sleve that cover the battries - Canon T70 35mm SLR Camera
  • 1,992 Answers
According to the pictures I see in the T70 manual, there is no sleeve required. It shows two AA batteries in the battery compartment, but no sleeve. Try just placing the batteries (properly oriented) into the well and closing the cover, and see if the camera powers on OK. You should be fine using it that way.
Posted on Feb 05, 2010
Oil leak around the dip stick sleve where it goes into oil pan
check your crankcase ventalation, (pvc valve, air hoses to valve covers)
Apr 13, 2014 | 1996 Volvo 960
Trl625 miles to kilometers
Look under the cover in the front of belt there will be a info pack in a sleve wich will tell you how to reclibrate and follow derections put in key while holding down a button and allow to calibrate
Nov 05, 2013 | Nordic Track Exercise & Fitness
How do u get the teflon sleve off the end of the tie rod by the rack and pinion ,inner
most dust covers are held in place by a special clamp that is made for a one-time install, this requires a set of wire cutters to remove..most that I have dealt with.. incidently the vehicle year and make arent posted with your question..please repost thnx..
Jan 19, 2013 | Cars & Trucks
Replace chuck on Makita cordless drill
The BTD 140 only has a sleve, spring, washer, clip and 2 balls. If you need to replace the bit holder then it is part of the shaft (324432-0) that comes from inside the gearbox.Cover unscrews from the body.
Dec 13, 2012 | Makita 18V LXT Lithium - Ion Cordless...
Dell latitude e6400 laptop bios override password needed
u can easilyn remove the bios password by removing cmos battry for abt 3 to 5 mins and in a laptop the laptop battry itself cointains cmos battry so u just need to take out battry and then switch ont the laptop without battry then insert the battry and switch it on again good luck
Jul 09, 2012 | Dell Latitude E6400 Laptop
Need the cover for the battrie department
if you need a battery cover for your camera you need to call their department, it is 1-800-5212010, thats where you can only get these battery cover
Apr 08, 2012 | Vtech Kidizoom Digital Camera
93 wide glide when i hit the start button all i get is a click i have all realdy clean the battrie cable and the battrie is full charged
remove the starter and the home plate shape cover. the plate covers the solenoid and can have carbon build up on those two contacts. It maybe fairly worn also and replacing is needed instead
Local starter rebuilding shops can repair this for you
Apr 24, 2011 | 1993 Harley Davidson FXR Super Glide
Need to change battrie in my wireless logitech mouse and don't have a manual. how to access the battries?
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Sep 08, 2008 | Logitech Cordless Wireless Optical Mouse...
Blown fuse
You need to go to your local Harbor Freight Tools and pick up a security tool kit for $9.99 so you'll get the bits required to remove the special screws. You need to remove all the screws around the outer edge of rear and then pull the white rubber plugs out of feet and remove the screws from feet. Then the entire cover lifts off of unit. That exposes where the power cord enters the back of unit. You'll see a smaller black wire leaving that area going over to the timer knob. Before the wire gets to the timer knob, there is a sleve covering the wire. If you'll cut the zip tie holding all the wires together, you can slide the sleve (mine is red) backwards toward where the power wire comes into unit. That will expose the inline fuse that is blown. You will need to call Delonghi to order the wire. It is pressure fitted on. You should be able to pull the connectors lose by hand on each end. Simple fix!!
Dec 28, 2007 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Installation
on the cover of the sleve the disk was in on a sticker
24 characters long separated by 2 - (dashes)
Dec 26, 2007 | Aiptek A-HD 720P Flash Media Camcorder
Canon T70 35mm SLR Camera Logo
65 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
