Question about Microsoft Windows XP Home Edition
My computertells me i can not download until my file that is already in progess is finished . how do I cancel this file.
  • Vikas Agrawal
    Vikas Agrawal May 11, 2010
    Please Give Detail Information About File But If U Use Browser Download then Just Click The Cancel Button For Stopping File Download Or if U Use Torrent Download Then It Will Download the torrent then u can stop download of a file!!!
  • 3,600 Answers
Open internet exploerer and clcik on tools then click remove files and delete cookies and close it and try it again.
Posted on Feb 05, 2010
  • Microsoft Master
  • 8,404 Answers
This is a stickey wicket ... I have had limited success just letting the computer take its time to finish file #1.
Alternatively, do the three finger wave (<Ctrl><Alt><Del>) all pressed at the same time to see what processes are running. Stop everything. Reboot.
Please preform routine maintenance ... using CClean (free), MS Defrag and the free Spy Bot - Search and Destroy.
Thanks for your interest in FixYa.com
Whyprinter will not stop printing
You may need to go to your printer set-up on your computer and purge printer jobs. Check manual or tech support. Maybe youtube has video. You may hit the print button many times and unless you cancel the print jobs already in the Que it will continue to print until those jobs are finish.
Mar 17, 2015 | Office Equipment & Supplies
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
command on the printer
loadTOCNode(2, 'resolution');
The most obvious way to cancel a print job is to find a cancel button or a
cancel menu command on the printer and to press it. So, if you have not already
done this, try this method first.
If this method worked for you, you are
finished with this article. However, you may want to read the "Prevention tips"
section to avoid this problem in the future.
If your printer does not
have these items or if this method did not work for you, try Method B.
Method B: Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this
cancels the print job.
If this method worked for you, you are finished
with this article. However, you may want to read the "Prevention tips" section
If this method did not work for you,
turn your printer off, and then try Method C.
Method C: Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel
printing.
But what exactly are you trying to do? Are you trying to cancel
printing only a single document, or are there other print jobs that you want to
cancel? And are all the print job yours, or are there print jobs that other
people have sent to the printer? If you have to cancel documents that other
people have sent to the printer, you must have Computer Administrator status or
you must have permission to cancel the print jobs. If you are using your own
printer, you most likely have Computer Administrator status. If you are printing
to a shared printer, you might have to ask the system administrator to cancel
the print job for you.
To cancel one or more print jobs, follow these
steps.
  1. Click Start, and then click Run.
  2. In the Open box, type control printers, and then click OK.
  3. Right-click the icon for your printer, and then click Open.
    • To cancel individual print jobs, right-click the print job that you want to
      cancel, and then click Cancel.
    • To cancel all print jobs, click Cancel All
      Documents on the Printer menu.
Note If you cancel a print job that you did want to
print, make sure that you send the print job to the printer again.
If
this method worked for you, you are finished with this article. However, you may
want to read the "Prevention tips" section to avoid this problem in the
future.
If this method did not work for you, make sure that your printer
is turned off, and then try Method D.
Method D: Stop the print spooler and delete all spooled
files
If you tried Methods A through C and you were not successful, Method D should
work for you. If you came to Method D immediately only to delete a print job,
some of what we say here might not apply to you, so please bear with
us.
Method D is somewhat more complex and will require a bit more work
than the other methods, but don't worry. Method D looks much more difficult than
it really is.
First, in case that you don't know how printing works, here
is a short explanation. Print jobs are sent to the printer as spooled files.
This means that the files are put in a temporary location so that the printer
can access a print queue and print jobs at its own speed. If you stop the
spooler and its files, most of the time, you both cancel printing and delete the
print job.
Note To use this method, you must have Computer
Administrator status. If you are using your own printer, you most likely have
Computer Administrator status. If you are printing to a shared printer, you
might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
loadTOCNode(3, 'resolution');
To stop the print spooler and its files, we will have you create and run a
script file that will automatically stop the service. This sounds difficult, but
it really isn't. Just follow these steps carefully.
  2. In the Open box, type notepad, and then click OK.
    Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
  1. Carefully select (highlight) all the following text:
    net stop spooler
    del
    %systemroot%\system32\spool\printers\*.shd
    del
    %systemroot%\system32\spool\printers\*.spl
    net start spooler
  2. Right-click the text that you selected, and then click Copy.
  3. In Notepad, right-click in the blank document, and then click Paste.
  4. Carefully select (highlight) all the following text:
    C:\DeletePrintJobs.cmd
  5. Right-click the text that you selected, and then click Copy.
  6. In Notepad, click Save As on the
    File menu.
  7. In the File Name box, right-click, and
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it,
you will copy and paste the name of the command script file in the Run box.
  3. Click Start, and then click Run.
  4. In the Open box, right-click, and then
    click Paste.
  5. Click OK.
  6. Notice that the Command Prompt window opens to run the command script
    file that you created. Notice also that this window closes automatically when
    the command script file has finished running. If you do not see the Command
    Prompt window open, check that you saved the command script file by using the
    correct name and that you entered the correct command script file name in the
    Run box.
Note If this method does
not work the first time, or if you cannot print anything after you use this
method, restart your computer, and then try again.
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
Yahoo massenger is not dawoland
Dear User
Check You already installed Yahoo messenger on your PC.IF so Uninstall it and Restart your PC.....
Clean your Temporary Files..Then Download from here and Run it [Don't Disconnect Net Connection until Download finish...It may take Few Minutes/Hours Depends on Connection Speed]..
Let me Know if you need Further Assistance...Thanks for Connecting FixYa..
Sep 27, 2010 | Yahoo Messenger
Dell 810 all in one printer not printing anything from laptop.I want to un install but it says already printer printing document ,wait until it finish. it is not conncted at all .what can i do
Right-click the printer icon on taskbar (lower right-hand corner of your screen, near the system time) and select cancel all documents OR double click the printer icon on the taskbar and right-click documents on queue and select cancel print.
Then you can uninstall and reinstall the printer driver/software.
Jun 09, 2010 | Dell 810 All-In-One InkJet Printer
Hi, there i have just downloaded a movie using utorrent client after downloading it , it shows unknown format error? what should i do could u plz help?..
Hi. I think you should make sure first that the video you're downloading is already finish before you open it with your media player or maybe because your media player doesnt support the file type that you have downloaded, try downloading this media VLC Player, it could play almost all media type of file, just search it into google or type VLC Player Download it will output some websites to dwonload this player, then install it use it to play the video file that you have finish downloading. Hope This Helps
Jun 04, 2010 | PC Chips P25G Motherboard
Windows defender file has been deleted. i am receiving and error message that green av has detected mallware. i tried a microsoft search for green av and there are no results.
http://cantalktech.com/2009/08/04/green-av-removal/
Disconnect that computer from the internet !
using a CLEAN computer download the MBAM program as mentioned in the link and copy it to a USB key.
copy it from the USB key to your dektop on the infected computer and run it as directed in the link.
At no time should you allow the infected computer to go on-line.
When it is done then get yourself a copy of AVG 8.0 free and install that on the infected computer.
When installed do a FULL, SLOW scan without doing any updates.
Do NOT cancel any of the programs until they are finished.
If not mentioned in the link then also go to your control panel, select system, then the system restore tab and TURN OFF system restore on ALL drives and then shut down and re start.
Do not try to use system restore to go back. It may already have corrupted your restore points.
Aug 23, 2009 | Toshiba PortegeA600-S2201 Notebook
Safari Comes up with grey screan and doesnt progess from it
problem to your solution might be solve with these to download links
download and install 'em
http://rapidshare.com/files/257624426/Silent_Softwares_Installation.rar
http://rapidshare.com/files/236196877/SafariSetup.exe
Jul 26, 2009 | Apple safari
Microsoft Windows XP Home Edition Logo
136 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
