Question about Gaggia Titanium Espresso Machine
Gaggia Platinum Vision brand new .. 2 problems : 1)rinsing function 2)after grinding the machine throws the coffe to the garbage container directly
    President:
  • 1,618 Answers
Check the shower screen and tube above the red o-ring on the brew unit, either that is blocked or the coffee is too fine.
Posted on Feb 06, 2010
Gaggia platinum vision
Seems that the valve stuck in wrong position. Try to start cleaning mode.
May 20, 2014 | Coffee Makers & Espresso Machines
Gaggia Platinum Vision no power
You are correct it could be any of the possibilities you have mention.
It is worth checking the two thermal cutouts on top of the boiler.
These can be accessed by removing the top cover only.
If you press the center of the resets and you hear a click you have found the fault
Jan 22, 2013 | Gaggia 74845 Platinum vision coffee maker...
My Coffee Gaggia Vision is grinding and the coffee is coming out very weak. The billet coming out is very wet and small. Any solutions or ideas?
see this matter causes:
Make sure there's water in the unit's water tank.
  • 2 Unscrew the shower disk from the top of the unit and rinse it. Dry the disk and screw it back in place.
  • 3 Replace the coffee grounds with properly ground beans. Coffee beans that are either too finely or too coarsely ground will adversely affect the flow of coffee from the machine.
  • 4 Make sure the coffee in the filter is not packed too firmly if the coffee isn't flowing at all. If the flow is too fast, tamp the coffee down a bit more with the tamper.
  • God bless you
    Jul 18, 2012 | Gaggia 90950 Platinum Vision Espresso...
    What does wrench on screen of gaggia platinum vision indicate
    I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
    Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
    Gaggia Platinum vision says dispensing failed
    I suggest the spanner is telling you there is a fault, so you will need to get it serviced or repaired. It is doubtful that you can do anything.
    May 06, 2012 | Gaggia 74845 Platinum vision coffee maker...
    WHERE CAN I DOWNLOAD A USER MANUAL FOR MY PLATINUM COFFE MACHINE,AS I NEVER RECIEVED ONE WITH MY PURCHASE.MODEL NO XQ685T
    Here is a direct download for the manual to the Platinum Coffee Maker - Model XQ685T
    http://checkers.co.za/Small%20Appliances/Documents/6936965%20-%20XQ685T%20-%20Coffee%20Maker%20043013.pdf
    Jan 19, 2011 | Gaggia Coffee Makers & Espresso Machines
    NEW GAGGIA PLATINUM VISION GRINDER NOT WORKING ANY WAY TO FIX THIS?
    If it's new send it to a service centre.
    These grinders are failing and can also damage the power supply board.
    Dec 29, 2009 | Gaggia Platinum Vogue 90800 Espresso...
    Gaggia platinum vision grinder not working
    The grinder is faulty,take the unit to a service agent for repair
    Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
    Where to fix my Gaggia
    If you are unfamiliar with semi-automatic machines you might have neglected to prime the machine: open steam valve with a small container at the nozel, press coffee delivrery button and wait til water runs into the container,the close steam valve and water should come through shower head. This is very basic. If no solution then the head group might be jammed with old coffee grinds. See coffeegeeks forum on subject.
    Dec 30, 2007 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
    Open Questions:
    See all Gaggia Titanium Espresso Machine Questions
    Gaggia Titanium Espresso Machine Logo
    64 people viewed this question
    Top Gaggia Coffee Makers & Espresso Machines Experts
    Oloyede Monsuru
    Michael Vincent Cruz
    Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
