Question about Dryers
I have a Kenmore series 70 Gas dryer model # 77732791. Does anyone know what motor it needs?
    Problem Solver:
  • 13 Answers
You must check this site,here you know what kind of motor is that.
http://www.washingmachineadvisor.com/
Posted on Feb 05, 2010
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 70 series gas dryer (Whirlpool model) will not ignite!!!!
>> Do you know where the flame sensor is located? I figure the ignitor is where the "glowing" occurs and the gas line feeds to. Thanks for your help!<<
The flame sensor is right next to the ignitor. Also see this link for what it looks like:
http://www.apwagner.com/index.php?main_page=index&cPath=7_96
Mar 18, 2010 | Kenmore 73952 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
Looking for information on a Kenmore gas dryer 70 series, model #77732791
The gas assembly is accessed by droping the kickplate/bottom panel. If the fuse mounted by the control klixon onthe blower housing has continuity then the control klixon will send power to the gas assembly when the drum temp drops below 105f. The thermostat/klixon will allow the power to remain on till the drum temp reaches around 160f. Then it will open and shut down the gas assembly and the drum continues to rotate untill the air drops below 105f and again the gas assembly gets power. When power is applied to the gas assembly it goes through the flame sensor to the ignitor and solenoid/coils. The ignitor draws so much power it is imposible for those solenoid/coils to open and discharge gas so when the flame sensor detects 1800f from the ignitor it kills power to the ignitor and that gives power to those coils. The gas comes out and hits the screaming hot ignitor. and whoosh you have fire. The fire only remains on till the temp reaches 160f and that does not take all that long. The constant cycling insures even heating so what can go wrong on this beast? Any component I just mentioned that is open (no continuity ) will be the problem. Now if the gas dryer works but then quits and works some more then replace those operator solenoid/coils. They can become intermittant with age.
Jan 18, 2010 | Dryers
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
