Question about GPS
My factory installed GPS gives a disc error, it says no disc or damaged disc.This is a 2006 jeep grand Anyone else having this trouble on the Jeeps?
I got this as a gift don't have program disc can you help me.
Posted on Feb 05, 2010
How to Check for Diagnostic Trouble Codes on a 1999 2010 Jeep Grand Cherokee?
You need a scanner or a OBD code reader, on this system there is no manual check. Follow the link to see what you need. OBD II CAN Code Reader with Multilingual Menu
Oct 14, 2016 | Jeep Grand Cherokee Cars & Trucks
How to close and lock the rear lift glass.
press it down and the latch closes. and locks.
on all jeeps.
if not the latch system is failing. (i own 2010) and JK 08.
the FSM covers this, read that yet>? posted 100s of times
see WK jeeps?
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Oct 18, 2015 | 2006 Jeep Grand Cherokee
How to remove a dashboard from a 1994 grand cherokee
XJ 94
its not bad, wana bet? 90% are not.
(i used to fix them)
so the PCM,. the FSM book covers that.
why not read that.
JEEPJX
PCM is baD ONLY WHEN inputs good, and its outputs are bad.
(and outputs not shorted) !!!
(same or all computers on earth)
lose of power to PCM or ground
or bad power.(weak, or intermittent)
Got DTC errors , post them?
innova 3140 best bank for buck on 93-95 jeeps. !!!
that is a low priced scan tool
are you having ASD relay issues?
http://www.fixkick.com/Jeeps/ASD.html
see XJ 95 here (same i think)
http://colorado4wheel.com/manuals/Jeep/XJ/
page 8D-23
engine bay next to Air cleaner.
to diagnose any car, a real scan tool is best.
or you will need a full lab of meters and scopes. like me.
the scan tool show up things the keyon/off trick does not.
http://www.fixkick.com/Jeeps/jeeps.html#poor_mans-scan
Mar 01, 2015 | 1994 Jeep Grand Cherokee
Why can't I hear the fuel pump?
on many cars , you need to crank it.
some have the prime key on for 3 seconds.
on jeeps.
check fuses first
check the ASD relay, if it dont energize the pump relay will be dead.
ASD >>> Fuelpump relay.
on jeeps, the ASD drops after 3 seconds, if the PCM sees errors.
Jun 30, 2014 | 1994 Jeep Grand Cherokee
Orange engine looking light on dash panel for 2006 jeep commander
It is probally the check engine light, If it stays on while you are driving,It should be scran before you have serious trouble with it,
Nov 27, 2012 | 2006 Jeep Commander
97 jeep Grand Cherokee loredo 6 cyl. Driving the car at any speed limit over 30mph going over a bump only the car starts vibrating like crazy. New Shocks new tires new tie rod and new bar that tire rod...
This is built into the car and is a nation wide complaint on all Jeeps. Contact the dealer for help or the factory assistance line. You could try adding more negative Castor adjustment to the front end , that may help.
Aug 07, 2012 | 1997 Jeep Grand Cherokee
I cannot find my oil pan. I have a 2005 jeep
jeeps are good for having skid plates to protect the under belly of the engine removing it should let you see the oil pan
Feb 24, 2010 | 2005 Jeep Grand Cherokee
My factory installed GPS gives a disc error, it says no disc or damaged disc. The dealer said their computer says no data link. He suggest trying another disc but does not have one and they are $200 which...
If you purchased the Envoy new it should have a 3year 36,000 mile warranty that should cover the GPS too. I would ask the dealer about it. If it is out of warranty I can get you a copy of the 2007 disk to try.
I hope this helps.
Buddy
tech@ccl-la.com
Jan 16, 2010 | GPS
How to take front rotors off 2006 jeep grand Cherokee
Remove the brake calipers and the rotors should come right off. If not, spray solvent into wheel stud holes and around the rotor/hub parting line and use a rubber mallet on the rotor (You can also use a piece of 2x4 and lay it across the rotor and strike it with a regular hammer.) From time to time some manufacturers use a flat screw installed in the rotor to hub face, to keep rotor on while going down the assembly line...check to make sure there aren't any on yours.(though I don't remember ever seeing any on Jeeps)
Sep 04, 2009 | 2006 Jeep Grand Cherokee
2001 Jeep Grand Cherokee 4.7L crank no start
easy trouble shoot easy fix ! check to see if its getting fire if not replace the crank sensor it will fire right up common problem with the jeeps . Hope this helps you out !!!
Jun 02, 2009 | 1999 Jeep Grand Cherokee
GPS Logo
71 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
