Question about Garmin Speed/Cadence sensor - GSC 10
Garmin Cadence sensor not working
No light flashing when reset button is presses. I am setting up cadence sensor for first time. Have forerunner 305 and magnet on crank arm aligned up with the line on cadence gadge. Changed the battery but still light doesnt flash when hitting reset. (Managed to pair it once when i removed battery and put it in backwards adn then reversed procedure). I thought it was sorted, but not so. Does reset button have to be held down for a period of time or pressed 2, 3 etc times?
3 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: turn garmin on it flashes the garmin logo then shuts down
hELLO THERE:
First off i would check the power cord to see if the fuse is bad and check the fuse in the car too
if all good than press and hold in the reset button for 2 minutes to let it fully reset it'self. and if this still does not work i would have the unit inspected by a authorized shop to see if the internal fuse has went out ok? i hope that these solutions have helped you out.
please dont forget to rate these solutions that i have provided cause it helps me so i can continue to help you too>
best regrds
MICHAEL
(UNITED STATES NAVY RETIRED)
Posted on Aug 22, 2009
johnegan84
  • 73 Answers
SOURCE: I have a Garmin cadence sensor now - will it work with new 500
Nope keep your sensor my 500 works fine with either
Posted on Mar 27, 2010
Cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Jul 14, 2009 | Garmin EDGE 705
I have installed my Garmin Edge Cadense Sensor, followed the instructions and seems like both the crank arm and wheel sensors are ticking and sensing. However, the edge does not seem to receive the...
There are two tests
705 first - settings, ANT+sport, accessories, check that cadence sensor is set to YES
press the reset on the cadence sensor and rotate the cranks - the LEDs should flash every time the magnet passes the sensor. if not its the position of the magent relative to the sensor that needs adjusting.
Hope that works
Jul 11, 2009 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
Cannot get my new cadence(WIND)sensor to work. will aparently teach. Any ideas
No reactions to any buttons:
Reset the training computer by pressing all the buttons simultaneously for two seconds until the display fills with digits. Press any button and set the time and date in Basic Settings after the reset. All other settings are saved. Skip the rest of the settings by pressing and holding STOP.
Polar Cadence Sensor W.I.N.D.
To activate the cadence sensor in your training computer, select Settings > Features > Shoes/bikes > Bike
1/2/3 > On > Cadence > On.
Teach new sensor? is displayed.
• If your sensor is already taught, select No.
• To teach a new sensor, make sure that there are no other cadence sensors nearby (40 m/131 ft) and then select Yes.
After selecting Yes, Start test drive is displayed. Rotate the crank a few times to activate the sensor.
The flashing red light indicates that the sensor is activated. Completed is displayed after the
teaching has been finished. The training computer is now ready to receive cadence data.
To return to time mode, press and hold the STOP button.
Good Luck,
Techjoel
May 08, 2009 | Polar Cadence Sensor W.I.N.D
I have lost the pace function since I have added cadence device
Not sure if this will help as I haven't tried it but I found on the internet if they lock up you can "reset" the device by holding MODE and powering ON at the same time (Push mode first). By "reseting" I am unsure if it puts everything back to factory settings, I am inclined to think so. BUT FIRST back up everything to PC as I'm sure all info will be lost on the unit.
Mar 28, 2009 | Garmin Forerunner 305 GPS Receiver
Recently purchased a edge 305cadenec/heart rate monitor.cadence is not coming up on the monitor. every thing else is working. Pushed the reset button on the sensor the speed light was fine the cadence...
Suggest you first try changing the battery in the sensor...then reset, then rescan for it on unit. It seems like quite a few have been shipped with dud batteries.
Oct 07, 2008 | Garmin Forerunner 305 GPS Receiver
Not able to get the cadence to regisger on the watch
Do you own the optional cadence sensor? If so you can only use it in Biking Mode.
If you own the sensor and are using Biking Mode. Then try a reset and if still no luck. Contact Garmin about getting it repaired.
Good Luck!
Jul 12, 2008 | Garmin Forerunner 305 GPS Receiver
Distance and average speed don't compute.
My solution included changing the battery in the cadence sensor (GSC10). You might not need to.
1. After changing battery, take bike outside. Turn on Edge 305 to acquire satellites (might not be necessary..)
2. Press reset button on GSC10. Should see red/green flash.
3. On Edge 305, go to SYSTEM.
4. Scroll down to ACCESSORIES.
5. On Accessory page, scroll to bottom, under Cadence Sensor, and press RESTART SCAN.
That fixed my Edge 305 - cadence and speed do appear now.
Apr 07, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305/GSC10 Cadence and speed sensor
Had the same problem. Here is how I fixed it.
1. Changed the battery in the cadence sensor. (GSC10)
2. Turned on my garmin 305 edge outside to acquire satellites (probably not nec but did it anyway)
3. Pressed reset on the GSC10, saw red/green flash (what order?)
4. Here's the missing step: On the Edge unit, go to SYSTEM.
5. Scroll to bottom, choose ACCESSORIES.
6. On acc. page, go to bottom, under Cadence Sensor, to the option RESTART SCAN. Press That. Now your cadence and speed should work.
Feb 23, 2008 | Garmin Edge 305 GPS Receiver
Garmin Speed/Cadence sensor - GSC 10  Logo
654 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
