Question about Magellan RoadMate 2200T GPS Receiver
Wont turn on- Magellan 2200T
Won't turn on???
  • Anonymous Sep 16, 2008
    Went to turn it on and had a black screen. Tried the reset and charging but still no luck.
  • gizguy Sep 29, 2008
    Tried the battery and no luck. Hooked up to an external power supply so I know there is voltage.
    Problem Solver:
  • 8 Answers
I answered this on another thread, I removed the back cover, 6 screws, and pulled the battery connector from the board, waited a minute or two, then reconnected. another poster said also that the connector for the power may have gotten loose, you can tighten that also but be careful. I did not have to do this, only the battery. Do NOT do this with a power cord plugged in, to be safe.
Posted on May 18, 2008
Car charger gets a green light but doesn't come on unless you fiddle around and turn adapter to find an area that will let the charger get power green light. this happens in all sockets. a good bounce...
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Jan 04, 2011 | Magellan RoadMate 2200T GPS Receiver
Hi stbbts
this is a very common problem with your model gps
Bill
Magellan Roadmate 2200T will not power on even after recharging and pushing reset button.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below (magellan 3000.3050 and the 6000 take about 10-15 seconds to start from the off position)
bill
Oct 04, 2010 | Magellan RoadMate 2200T GPS Receiver
My gps on turn on
if you mean it Wont turn on..follow the advice below.
bill
Jul 27, 2010 | Magellan RoadMate 2200T GPS Receiver
Roadmate 2200t wont charge even after replacing with a new battery
hi rocco_berard
Bill
Jun 29, 2010 | Magellan RoadMate 2200T GPS Receiver
Magellan RoadMate 2200T won't turn on
ost times not turning on is because the battery is flat or dead. Connect it to a USB charger or and AC charger and leave it for an hour to see if there is any recovery.
If it does not have it taken to a service centre to have the charge circuit checked and a new battery.
Please rate my help++++Thanks for using FIXYA
May 14, 2010 | Magellan RoadMate 2200T GPS Receiver
Magellan Readmate 22007 turns on, but won't leave
try the reset if you havent already, if that fails or you dont know how, just respond to this post..the update might cure it, but it sounds like the digitizer (the touch part of the lcd) is out.
if thats the case and you want help getting a new one (digitizer) just reply to this post.
bill
Jan 13, 2010 | Magellan RoadMate 2200T GPS Receiver
I just bought a good used Magellan 2200t for my son wont turn on
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, here
if the links dont work or If you need further help, just let me know.
Jan 04, 2010 | Magellan RoadMate 2200T GPS Receiver
Magellan RoadMate 2200T will not go on
hi bullockbob
Bill
Nov 25, 2008 | Magellan RoadMate 2200T GPS Receiver
Magellan RoadMate 2200T GPS Receiver Logo
60 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
