Question about HP Office Equipment & Supplies
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to say the problem started a year ago when the black cartridge completely ran out and the printer refused to function until the black cartridge was replaced. The printer has never been the same since then. Any ideas?
    Genius:
  • 1,089 Answers
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Posted on Feb 12, 2010
Yelllow color is not printing
check yellow cartridge to see if toner seal tab has been pulled out
Aug 31, 2014 | HP LaserJet 2840 All-In-One Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Hi, my printer is a HP Color Laser Jet 2605dn. I've had it for several years and it's proved to work fantastic in all areas. However, in the last few months, I've had color issues. The printer prints out...
This printer does not use ink cartridges. It is a laser printer and uses toner cartridges. Yes, one or all three toner color cartridges maybe running out of toner.
Nov 09, 2010 | HP Color LaserJet 2600n Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
My Hp LaserJet 2600n stop black stop printig
the problem is cyan and yellow toner are low, u will change the cyan and yellow it will be cleared otherwise the will be empty u can't print any thing suppose one will empty other cartridge will not work
Aug 26, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
130 people viewed this question
Seeker5211
Seeker5211
