Question about Goodman GMS90703BXA Heater
Goodman Dependable 92, ignitor and fan comes on for 3 seconds, furnance does not turn on. Goes through 3-4 cycles, then shuts down furnance. If it is the flame sensor, where can one buy parts?
  • 767 Answers
Do the burners come on? If so then yes it probably is the flame sensor if not then there is another issue not the flame sensor. The flame sensor could just be dirty take the flame sensor out and clean it with a piece of emery cloth or lite sand paper and put it back in and this should get the burners to stay on.
Posted on Feb 05, 2010
  • refriend Mar 09, 2011
    Perfect... you just saved me $120. Go grab yourself a beer.
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
I have a Goodman gas furnance. The furmance kicks on the glow rod lights and then the furnance shuts down after about 60 seconds it goes through the same cycle. The burners never come on. What's wrong?
Let's trouble shoot a few possibilities:
Can you confirm that your gas pressure/ supply is correct-- by lighting all of the range top burners at the same time-- Do they all light quickly, and burn to full height, without much of any yellowing at the flame tips? That should indicate you have god gas pressure and supply.
Now-- in the Oven itself-
When you light the BROIL burner-- does it's glow ignitor light up, and does that burner light off OK?
If it is only the main oven burner that is not lighting, are you able to remove the cover plate that covers it, and watch it light off? -- Any clues on whether or not the gas valve even open?
If NO gas flow, likely you need a new Main Oven Gas Valve-- Probably need to call your Gas Appliance service person.
Let us know if this helped
Mack B
Jan 23, 2011 | Goodman GMS90703BXA Heater
Gas valve is not kicking in or gas shut offs are off. Can you check voltage where 2 wires connect to gas valve. Can you see blinking lights thru lower door window and count blinks. Code sticker should be on inside of lower door.
Jan 23, 2011 | Heating & Cooling
The furnance ignites for about ten seconds the right befor the blower comes on the furnance goes out. This repeats itself over and over until the unit shuts itself down.
Take out the flame sensor and clean it with a piece of sand paper or emery cloth and put it back in and this should get sustained flame.2e77348.jpg
Feb 25, 2010 | Goodman GMS90703BXA Heater
Heater keeps turning on & off but no heat
What type of heater are we talking about? if its the home furnance, it sounds like the ignitor is coming on and shutting back down, the heat comes on ignite and the blower comes on like normal, then after a few minutes it will shut down, you will have to remove the ignitor, clean it with a little piece of sand paper to remove the carbon build-up, replace the ignitor and turn the furnance back on, this should correct the problem.
Dec 14, 2009 | Heating & Cooling
Goodman GMT070-3A heater. When heater is turned
look for flashing code thru blower door peep hole aftter it shuts down and let me know the amount of flashes
Dec 03, 2009 | Heating & Cooling
Limit Switch
It is rare that a limit switch goes bad. It is a safety control. If it is shutting off your furnace there is a problem that it is protecting you from.
If the limit switch is shutting the unit down your furnace is overheating. Check the filters. Check for any obstruction in the blower assembly. Check to see if you can raise the blower speed. Make sure all registers are open in the house. Your evaporator coil could be obstructed if you do not take good care of your filters.
Feb 28, 2009 | Goodman GMS90703BXA Heater
Goodman Dependable 92 blowign cold air only - no heat
blowing cold air on this furnace usualy caused by high limit trip, or flame roll out. the first one, (high limit) is from insf. air flow. (blocked filter,bad zone damper?
The second,(flame roll out) caused by bad heat exchanger,blocked vent.ect.
Jan 09, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
859 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
