Question about NetGear PS101 Mini Print Server Print Server
PS101 Netgear Print Server quit working
For some unknown reason, it appears that my PS101 has either lost it's IP address or reset to something outside of my normal parameters. There does not seem to be a reset feature. Any ideas?
    Sergeant:
    Champion:
  • 265 Answers
Have your run the setup software again?
Posted on Feb 05, 2010
Jetdirect ex default ip
Usually it it set to pick up IP from DHCP/BootP.
If someone had assigned a fixed IP and it is now unknown. It is better to reset the print server to factory default by pushing the little reset button,
Then check you DHCP server for the newly assigned IP address.
You will need a version of HP Jetadmin or HP webjetadmin to configure this print server
May 13, 2014 | HP JetDirect EX Plus Print Server
My netgear ps101 went sleeping, cannot be ping. But after power on/off it's ok, then not long after that it went sleeping again.
Somewhere in the setup instructions type the ipaddress of the router in internet explorer and if you have the correct credentials to get in this device you may set the sleep time or shut that off
Jan 27, 2011 | NetGear PS101 Mini Print Server Print...
When Verizon installed a new a new service I lost computer-printer communication. Do you have updated software to re install the print server again? Thank you for your help
you need to reinstall you print server
following is steps to reinstall print server
1. connect printer to print server with USB cable
2.print server to computer with CAT5 cable
3.put the CD (which you got along with print server) in computer
4.follow instruction step by step
5.It will asked you for IP address, you need to assign IP which is withen the range of your verizon modem(for example 192.168.0.50
after that it going to work
regards
prakash
Feb 12, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
I had a PS101 hooked up to an older wireless router. It was working fine on my new Vista Machine. The router died and just installed a NETGEAR WGR614 Wireless Router 802.11g. Now it doesnt see the print...
This was more hastle than it was worth. So I bought a new print server (twice), neither worked either. Might be the router, but after spending 2 hours on the phone with INDIA, I said forget it and took it back, bought a parallel card and gonna hook it up with a cable!
Jan 01, 2010 | NetGear PS101 Mini Print Server Print...
I need IP address for print server WGPS606
The default IP address of the print serer is 192.168.0.102
This print server works as DHCP client. it will automtically pick an IP from the DHCP, unless assigned statically.
Jun 08, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
I have a netgear wgps606 wireless print server. I
Manual Configuration of WGPS606 Print Server
Note: Before configuring the printer server please check if you printer is compatible. You may open this link to you web browser: http://kbserver.netgear.com/kb_web_files/N101216.asp.
1. Please make sure that the printer works when connected directly to the computer.
2. Confirm the wireless settings of your router. You should have the SSID, wireless security and IP address of the router.
For NETGEAR routers please follow these instructions to check the wireless settings:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab and you may get the wireless settings on that page.
e. On the left side under Advance setup, click on the LAN IP setup and locate the LAN TCP/IP Setup. Underneath that is the IP address of the router.
Note: If your IP address is 192.168.1.1, then you may use 192.168.1.200 for your print server.
3. Please connect a computer to the print server. At this time, the router is not connected. The printer should be connected to USB1. The power, LAN port and LPT1 should be lit.
4. Assign static IP address to the computer.
a. Click on Start and right click on Control Panel.
b. When the Control Panel window opens, double click Network Connections.
c. Right click on Local Area Connection, then click Properties. When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then hit Properties button.
d. Change the option from Obtain an IP address automatically to Use the Following IP Address and enter the following:
IP: 192.168.0.50
Subnet Mask: 255.255.255.0
Note: Leave the default gateway and DNS addresses blank.
f. Click on OK and then Close. Exit out of all the Windows.
5. Ping the print server.
a. Click on Start and then Run. Type cmd and hit OK.
b. On the DOS prompt, type ping 192.168.0.102. This should give four responses.
c. If it gives request timed out or destination net unreachable, please turn off both print server and computer. Wait for few minutes, then turn it on again. You can also try holding the reset of the device. Then repeat steb 5.b.
6. If you are able to get replies, you may now open Internet Explorer and type 192.168.0.102 on the address field.
7. After hitting go or enter on the address field, it will ask for a login. (Please type in admin for Username and password for Password).
8. Click on Wireless Settings under Setup tab and we need to set the same SSID as your router.
9. Please also select the appropriate Wireless Security and type the network key or wireless password from the router. Then click on Apply to save the settings.
10. When you get back to the page, click Print Server settings.
11. Check Change to and set the following:
IP address: 192.168.1.200 (It should be on the same range as the router. e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). This will be the print server's IP address.
IP mask: 255.255.255.0
12. Click Apply to save the settings. We will get a Page cannot be displayed.
13. Set the IP address of the computer back to dynamic.
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then click on OK.
For Windows 98 and ME:
a. Please click on Start, then Settings, and then Control Panel.
b. Double-click Network then select TCP/IP for the Ethernet adapter. Then click on Properties.
c. Go to IP address tab and select Obtain an IP address automatically.
d. Click on the Gateway tab and delete the numbers under the Installed Gateway.
e. Click the DNS Configuration tab, and then select Disable.
f. Click on OK. Windows will then prompt for a restart.
14. To set up a TCP/IP port to the computer, please follow these steps:
b. Double click on Printers and Faxes.
c. Right click the printer icon and go to Properties.
d. Click Port Tab and click Add Port.
e. Select Standard TCP/IP port. Hit OK or Next.
f. In the field for Printer Name or IP Address: enter the IP address of the Print Server and click on Next.
g. Select Custom and then click Settings.
h. Under Protocol select LPR, and for Queue Name, type L1 if printer is connected to the print server USB port 1 and L2 if the printer is connected to the 2nd port.
i. Click on OK, then Next, and Finish.
j. Lastly, please right click on your printer icon and select Use Printer Online. If this is not an option, disregard it.
15. Check if you can print through the print server.
16. If it is not printing, then please try to connect the print server to the router and check if you can print. If it can, then there might be a need to re-do the steps for wireless configuration of the printer server.
Mar 29, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Netgear Print server
IP: 192.168.0.50
Dec 18, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
Unknown address
Install Network Manager in your and install . When you install this software then you go to networkingmap there you will get ipaddress of your print server
Apr 18, 2008 | D-Link DP 301U (DP-301U) Print Server
Print server
Check the port configurations on both XP machines. It should have the IP address of the print server connected to the plotter.
Aug 01, 2007 | NetGear PS101 Mini Print Server Print...
Why so slow?!!!??
Matt C., I bet that your 'IT guy' installed the Netgear software on each PC. He should have installed it on only 1 PC and used it to set the IP, Subnet Mask and Default Gateway on the PS101. Use the 'Printers and Faxes/Properties/Ports' tab of the printer to get the IP, you'll need it in a minute. Download and expand the appropriate Drivers for the printer, or have the CD ready. Remove all instances of the Netgear software from the PC's if your PS101 is configured (Use the 'Control Panel / Add-remove software') Once the PS101 is configured, you can install the 'network printer' on all 3 PC's using the following method (assuming WinXP): Click 'Start' Click 'Settings' Click 'Printer & Faxes' Click 'Add A Printer' When the 'Wizard' opens up, click 'Next' Make sure the option for 'Local printer attached to this computer' is selected, but DO NOT select 'Automatically detect and install my Plug and Play printer' Click 'Next' Click 'Create a new port' Using the 'drop down' select 'Standard TCP/IP port' Then click 'Next' twice In the field 'Printer Name or IP Address' enter the IP that your 'IT guy' assigned during the initial setup (You should have that from the 'Printers and Faxes/Properties/Ports' that I referenced earlier. Click 'Next' You should see 'Standard: Generic Network Card', if so click 'Next' then 'Finish' The 'Add Printer Wizard' should open. Click 'Have Disk' and browse to the folder that you expanded the drivers for the printer into. Click 'Print Testpage' Click 'Finish' You should be printing a lot faster. Let me know if this doesn't work, or isn't clear!
Nov 16, 2006 | NetGear PS101 Mini Print Server Print...
NetGear PS101 Mini Print Server Print Server Logo
257 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
