Question about All-Pro Heating & Cooling
Fires up and runs for 2 minutes and then cuts out. pressure is set properly and has a new sensor eye in it. the reset button keeps kicking out and shutting the heater down
  • 1,420 Answers
Replace the primary control (the component that has the reset button).
Posted on Feb 05, 2010
With only one adjustment *****, can't figure out how to adjust cut-in and cut-out levels.
There is only one adjustment screw because it has a fixed differential. A 20 lb differential is standard. I recommend a 40-60 pressure setting which gives you an average water press of 500 psi. With a 40 cut-in, your tank pressure should be set at 38 psi. There is a schrader valve at the top of the tank. Use a tire gauge to set it at 38 psi. Do that first. Now set your press switch by running water and observing at what pressure the pump kicks in at. Don't worry about the cut-out pressure. It's trial and error.
Let the pressure build up above 45 psi and then run water until you hear the pump kick on. Keep doing this until the pump kicks on at 40 psi. It may take a few tries, so I recommend having someone else turning the water on and off for you.
Apr 14, 2016 | Plumbing
Just put new tires on my 2008 dodge ram1500 now low presure light is on no sensors in velvestems how do i get light off
Hi
1: set the tires pressure ( including spare tire) according to the sticker on the door side,
2: drive for 10 minutes at speed more than 15 MPH
3: park and keep the engine running, press the button ( light load) to reset the tires pressure and hold it for 10 sec.
Good luck
Aug 15, 2014 | Cars & Trucks
1994 Ford Ranger 4.0 cranks runs about 1 to 1 1/2 minute and cuts off.
There are 2 relays in the relay box that could cause this problem the EEC relay and the FUEL pump relay the best test for EEC relay back probe the throttle position sensor for the 5 volts reference signal run engine and watch to see if you lose this voltage. and fuel pump relay install a fuel pressure gauge to fuel rail service port and check to see if pressure drops to zero.
Mar 22, 2014 | Cars & Trucks
2000 ford ranger stalled when brakes were locked up. Now it Wont run.
Check your Inertia sensor. This is usually behind a kick panel at the base of the carpet. It has a reset button. Vibrations and Impacts will activate this part and cut off fuel power.
Mar 01, 2013 | Cars & Trucks
Hi I have a old unit built in my bedroom closet! I hear heat pump sleep pump...? Well anyway it runs off water for cold air then returns (recycles) for the heater! There is only one part to my unit (In...
Seems like 80-85psi is too much supply pressure. I would adjust the pressure switch on your well pump. If it's a 1 horse pump or so- you should be able to go buy a new pressure switch that is pre-set for about $20.
Jan 20, 2011 | Heating & Cooling
I have an 08 eclipse gt with 3000 miles on it. It is automatic. I kicked down the other day to pass a car. About the time I got around the car my motor cut off and would not restart for about 5 minutes. It...
You may have had something obstructing the fuel flow keep a eye an see if it happens again. If your car is that new you should have a warranty take it back to dealer let them worry about it .Dont work on it yourself because you my actually void out the warranty
Sep 13, 2010 | Mitsubishi Eclipse Cars & Trucks
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Abs fault light on ,fault finder keeps flashing
you will find that its a faulty actuator common fault.somtimes its the front somtimes it the rear they are costly buy a manual on disc from ebay and go though the checks.
Oct 01, 2009 | 1991 Honda ST 1100 Pan European
Bmw 318t1 sport. cold start problem and cutting out.
i would try getting the ecu checked over and check the dizzy cap for cracks.
Jan 21, 2009 | 1999 BMW 318 ti
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Heating & Cooling Logo
175 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
