Question about Alpine Audio Players & Recorders
Plz send me ssb-120 pa amplifier circuit digram
  • 1 more comment
  • firoz khnan
    firoz khnan Jan 24, 2014
  • Anonymous Mar 15, 2014
    i want get ahuja ssb 120 service manual
  • asanka
    asanka Mar 15, 2014
    can u send me it
    Scholar:
  • 73 Answers
Hi i think this is what you are looking for, takes a while to load but checked and its the full instruction manual.
http://ahujaradios.com/Literature/SSB-120_OM.pdf
please rate :)
Posted on Feb 05, 2010
How do I hook up my realistic mpa 25 20watt pa amplifier
hook up speaker common wire to com,then hook up the speaker wire to whatever ohm the pa speaker is,regular ones are 8 ohm,stay away from 70 v,plug in a record player or aux in the rca jacks you can use 12 volts or 120 volts
Jul 21, 2015 | Audio Players & Recorders
I have a Denon PMA 500V amplifier. all of the output fuses were blown so I replaced them but the unit still doesn't work. Any suggestions?
hi.
Did you checked balanced impedance?load speaker impedance vs PA output?or PA might over driven,causing a trouble on the pre-amp to power amp circuits and components damage,
need to recheck related components on the pre-driver up to main output section,
Note: That,blowing of fuses with the same rating is an indication of trouble/shorted in a circuits that driven on it,
Thanks and good luck
microhit
Jun 01, 2011 | Denon PMA-2000R 2-Channel Amplifier
Please, send me a circuit diagram of QSC(RMX 2450) AMPLIFIER if you have.
hi,
its with me. if u need the same contact me on my mail.
ajingopakumar@yahoo.co.in
ok
Jan 28, 2011 | Peavey SP2 PA Passive Speaker
148 GTL 120-Channels Base CB Radio: my 148 throws a key to my bench radio but sends no...
Hi
try replacing the transistor just before the last on the rf pa output.
Hope this helps
Ray
May 15, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Aug 10, 2009 | Audio Players & Recorders
No modulation in AAM only mode. Needing a schematic.
if the transmitter produces power output with modulation on SSB but NOT ON AM then the AM Pass Regulator is defective, more times than not.
May 24, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
MPA-101 Amplifier powers on, receives source signal, the fuse is not blown inside, but no sound comes out of the amplifier. The amp is pretty new, doesn't even have dust inside the unit.
Hello, is this a Radio Shack PA amp or Jamo amp? The unit is probably in "Protect" mode. Is this a PA system or a receiver...receivers have a protection circuit that will not let the speaker relay activate if the amplifier output section is shorted and sending voltage towards the speakers...so they won't fry!!The speaker relay should activate within 3 to 5 seconds if your output section is ok.
barneyluc
Oct 13, 2008 | Audio Players & Recorders
CIRCUIT DIGRAM
You should be able to find the service manual for your set at the following link and it should include part numbers for the items in question. http://www.servicemanuals.net/
Dec 29, 2007 | Televison & Video
283 people viewed this question
Top Alpine Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
SHARCNET-USA
SHARCNET-USA
Are you an Alpine Audio Player and Recorder Expert? Answer questions, earn points and help others
