Question about Panasonic PT-53WX52 53" Rear Projection Television
Sound, no picture
Sound is perfect but the screen is black, no picture and no displays. the
tv systems have been check everything appears to be working, the vertical
chip has been replaced, voltage is fine, What could this be?
I had the same problem and mine was a lose soodering conection this was on a 46' flat screen manufactured in 96 hope this helps
Posted on Sep 28, 2008
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
TV shuts off after 3 seconds
If the sound is still heard then the inverter board has failed and is triping the powersupply,if no sound the powersupply has failed.
Len..
Mar 29, 2014 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
MY KAWASAKI T.V. IS HOOKED UP TO COX AND HAS WORKED PERFECTLY UNTIL I TRIED TO TURN IT ON AND IT APPEARS THAT IT IS NOT GETTING POWER. NO PICTURE; NO SOUND, JUST BLACK SCREEN.
Check all your power connections.. unplug everything.. plug it back in. If you are using a power strip make sure that it is functioning properly. If it is still under warranty contact the company that makes it. If not.. either look into someone that is smart with electronics to check the insides for a blown fuse or consider buying another one.
Mar 20, 2011 | Televison & Video
How to fix TV
I have a large black square obscuring the picture. You can see the picture in 1 inch border around the black square. If I reset the input switch, the black square disappears for about one second (the picture is momentarily perfect) and the black square appears again. It is not the cable box because I wired the cable directly into the tv. The same thing happens when I try to play a DVD. Any insights????
Mar 08, 2009 | Mitsubishi CS-35305 TV
20 inch wega @1999 Picture comes in and out
Try to finde lose connection/ cold solder joint at board attached at end of picture tube. It seems heater/ filament voltage not being supplied to picture tube after a while and picture goes to black.
Jul 22, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Sound but No Picture
Perhaps your remote is set to video recorder?  Try that first, and if no response, try calling up a menu on your TV and look for the Picture Settings.
Good Luck.
Nov 03, 2007 | LG 37LP1D 37 in. LCD Television
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
Panasonic PT-53WX52 53" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
