Question about Dell Latitude C610 Notebook
System does not come up
Hi, When I push the power button, the hdd and power on light flahses as well as caps,scroll and numlock keys. Then system goes off.
Kindly assist.
    Guru:
  • 1,481 Answers
I guess ur motherboard is gone...
also check if can boot from BIOS...do u get the BIOS screen when u press Del/F1/F2 key immeditaly after u switch on...
if yes then ur MB may be ok...else my guess could be correct
Posted on Feb 05, 2010
How do I unlock my keyboard? On the top right hand corner there is a silver Dell button(that's what it looks like). There are 3 lights with 3 lock emblems, one has the number 9, one has the letter A a
Those "lock" lights are for the NUMLOCK, CAPS LOCK, and SCROLL LOCK features. With each press of the NUM LOCK key, the "9" should cycle on and off. With each press of the CAP LOCK key, The "A" light should cycle on and off, and so on.
Jan 25, 2015 | Dell Computers & Internet
How do I get the num lock off so I can type letters like j,k,l,m,ect.. ?
Hi there before use those key you have to disable the numlock key first. Press FN hold & press ( Numlk ) blue marked key. You will see then the numlock light will goes off. Its mean that deactive now.
Apr 13, 2010 | HP Compaq Presario V2000 Notebook
Dell Dimension 4700
Try resetting the BIOS, see if the drive re-detects
  1. Boot to BIOS F2
  2. turn on all 3 lock lights (NUMLOCK, CAPSLOCK< SCROLL LOCK)
  3. Press ALT+E, then ALT+F then ALT +B and system will reboot and re-detect drives
  4. If HDD is not detected, reseat data and power cable connections, try again
  5. if still no go, then HDD has likely failed
Mar 21, 2010 | Dell Dimension 4700 PC Desktop
Hangs on startup no video, no audio power light and harddrive access light are lit as are numlock, caps lock, and scroll lock.
remove the ac adapter and battery then press the power button for about 15seconds then reconnect the power sources and turn on the system. if it still doesnt turn on correctly, reseat the memory.
Dec 03, 2009 | Sony VAIO VGN-N320E Notebook
When my keboard was connected to the system unit there was light on the keyboard but all the key are nt responding
Turn you computer off. Check to see if the keyboard is plugged in all the way. Now turn the system on.
Do the lights on the keyboard flash when the system turns on?
Can you push the caps lock key and get the caps lock light to turn on?
Can you push the numlock key and get the numlock light to turn on?
No? Well I would then try another keyboard. It's quite possible yours is broken.
Sep 24, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
Inspiron 1525 power light is on but computer wont work
Some details please? Does the system show any video on the LCD? Do you hear any Windows Startup Sounds? Are the Lock lights (Caps Lock, NumLock and Scroll Lock on/flashing? If you have none of the above, then remove the HDD, Optical Drive, RAM, Modem, external devices/docks and wireless cards and see if anything changes. If nothing changes, thenmost likely a motheboard issue. Replace ment motherboards run $150 to $250 on Ebay
Jun 12, 2009 | Dell Inspiron 1525 Laptop Jet Black
Can not use my t an y on keyboard,all other keys ok,only get working pressing numlock an scroll lock
Check regional languages in control panel are set correctly.
Put your language to the top and save it.
update the Operating system too.
run a virus scan
Should be good.
Possible new keyboard, May be damaged.
Apr 21, 2009 | Computers & Internet
Dell Inspiron 5160 wont turn on
I would suggest that first try running the psa test on ur system which could b done by press and hold FN key and power button together and leave it as soon as u see anything on the screen or any led in case u get any error code or beep sounds then it has to do with hardware and u ned to contact dell in case ur system is still under warranty.which lights do u see come up when u press the power button.I guess u r talking abt the led's for capslock , numlock and scroll lock.try reseating the memory module from the system and try running ur system on one memory chips and vise-versa because it seems that may b the prob is with the memory sticks.
in case u want manual for removing the memory sticks try using support.dell.com and u would get the manuals from there.
Feb 03, 2009 | Dell Inspiron 5160 Notebook
Dell Latitude C610 Notebook Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
