Question about PfaFF Creative 7570
Runs normal and then it is strainng to even go. This is a Pfaff.
Is it normal for the Pfaff snips cutter to be extremely noisy?
I bought a new Pfaff and was alarmed at how noisy it was, particularly the snips cutter. This was unacceptable and I sent the machine back, but I don't know if all machines with snips make this awful noise.
Apr 05, 2017 | PfaFF Sewing Machines
Pfaff expression 100th Anniversary
have it serviced as the needle timing may be out causing the needle to hit the bobbin hook
Oct 23, 2015 | PfaFF Sewing Machines
Pfaff 1221 sewing machine stuck in reverse
if you can take the pfaff back and tell them what its doing and have them fix it or get another sewing machine..
Sep 06, 2013 | PfaFF Sewing Machines
Pfaff creative vision running too slow
Good morning
Embroidering is difficult enough by hand. Computerized embroidery is even more complicated, a lot of things going on simultaneously. I am inclined to think that there is more going on than the machine can handle at the same time.
Check if you can have fewer programs open at the same time.
Maybe try with one type of thread and see if it speeds up, then add slowly one by one.
good luck
kolbrun
Jul 05, 2012 | PfaFF Creative 7570
Are pfaff 1475cd sewing feet compatible with pfaff 1151 machine
Hi. Some Pfaff machines have something called an "IDT" which looks rather like a small, black walking foot behind the pressure foot, to help feed the fabric evenly. Pfaff machines with this IDT need "IDT" pressure feet. (I can't find a listing of which machines have this and which don't, so you'll have to look at your machines or check your manuals.) If both machines have the IDT, then the feet are compatible. If neither has the IDT, then the feet are also compatible.
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | PfaFF Sewing Machines
Can you get me a Pfaff 1222E motor please? Th
You will need a Pfaff dealer or go direct to the manufacturer or even go on ebay and try and purchase a similar model which may be cheaper thanh a new motor and you can then swap motor over.
Jan 31, 2010 | PfaFF Sewing Machines
I can't get my Pfaff 230a to straight stitch!
The stitch selector switch is most likely the culprit. Have you tried operating the machine upside down?
Jan 17, 2010 | PfaFF Sewing Machines
Pfaff 1222 and pfaff 1229
Have a certified repairman look at the power board in the machine. The power supply circuits are broken on the board itself. Can be repaired with wire and solder. How do I know? Just fixed my wifes 1229 that had the same problem.
P.S. New boards are NOT available from PFAFF or anyone else
Sep 26, 2008 | PfaFF Tiptronic 2030
Pfaff 2029 sewing machine.
No the sounds are not normal,
I would suggest you have the machine looked at by a sewing machine tech.
I have never come across this problem before and would need to look at the machine before making a diagnosis.
Sorry to be of little help but it would be unfair to give bad advice.
Mar 31, 2008 | Sewing Machines
Pfaff creative 1469 instruction book
I have the patterns book for it, but not the normal instructions manual, shall we trade? --> pfaff [at] 0j0.org
Jan 07, 2008 | PfaFF Creative 7570
Sewing Machines Logo
35 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
