Question about Samsung LE26R74BDX 26 in. HD-Ready LCD Television
Band of dot's(millions) across screen only whilst watching in hd mode and whilst using any menu option such as volume etc. dot's not there whilst watching any sd programes
  • 219 Answers
I think I have a good idea of what you're experiencing.
Our minds are so set in the low-def mode that when those extra lines are filled in for high-def it looks like a bunch of dots. Notice everything is so much more clear? I thought the same thing when I watched my first blu-ray disc.
Watch something in high-def and then go back to standard immediately after. You'll notice that you can't get near as much detail off of the low-def.
Those dots are your mind trying to put high-def into low def.
Hope this helps; please rate my solution accordingly
Respectfully,
Don
Posted on Feb 05, 2010
Why does TV not come on After previously watching it. It appears that after a long delay that I found sometimes the TV will come on can you advise me of the fault and what's required to remedy it.
It sounds like your tele maybe in store demo mode..To remedy this press the side button for volume up & whilst the volume up is displayed on the screen press & hold menu...On screen should be either Store/Shop mode Or Home/Standard mode select your preference & it should be ok.Good luck.
Aug 16, 2016 | Samsung LN32A330 32 in. LCD TV
How do i set convergence of red,green ,blue through service mode
Most common cause for this on the Sony KDL 40EX520 is that the connections to the screen across the top edge of the panel become loose causing blurred picture, mis-aligned colors etc. The Fix requires dis-assembly (Removal of the entire case) and re-seating/resecuring the connection across the top of the LCD Panel.
There is a pretty detailed video of the process (less the disassembly) here: https://www.youtube.com/watch?v=80PfZXFGDvQ
Jan 10, 2015 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Movies and shows don't fit the screen. Can the settings be adjusted so credits etc can be read
Don't know why you want to read the credits ;) but:
In the TV menu, you may have a choice of how the picture is displayed. These options may be called
1)dot by dot
2)stretch
3)super stretch and
a 4th that escapes me.
If you've got HD, switch it to dot-by-dot. If not, switch it to stretch.
My Sharp Aquos has this. Your's probably has something similar.
Nov 16, 2009 | Panasonic Televison & Video
Screen shuts off. Power lite blinks. Aquos 42"
Hope you have the correct resolution selected:
HD View Modes: When viewing an HD program you can select the following 4 viewing modes.
  • Stretch: suitable for viewing 1.78:1 DVDs. When viewing 1.85:1 DVDs, this mode will show thin black bands at top and bottom of the screen.
  • Dot by Dot (1080i/p only): detects the resolution of the signal and displays an image with the same number of pixels on the screen. When a 720p signal is being input, the image will be delivered in full screen.
  • Smart Stretch: suitable for stretching 4:3 programs to fill the screen.
  • Zoom: suitable for viewing wide-screen 2.35:1 aspect-ratio programs in full screen.
PC View Modes: You can connect the TV to your PC through the HDMI inputs to use the TV as a monitor. The following view modes are available in PC mode.
  • 4:3 Input Signal: You can select between Normal, Zoom, Stretch, or Dot by Dot.
  • 16:9 Input Signal: You can select between Stretch or Dot by Dot.
Also verify if you have set auto timer to 30 mins or so thats why the TV shuts down after a particular time.
Thanks
May 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture is to big for screen
Menu go to setup,go to reset,well be back to factory setting.U will have function to view mode,not than ur video backlight board have problems.
Apr 30, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
How to use face detection
Hi
Turn on camera as if you were taking a photo. Whilst holding phone vertically, in bottom right of screen you have a box image with lines. Below this on the keypad you have a 'soft key' (right hand '-' key) Press this and it takes you into camera settings. Turn phone horizontal and there is a menu across the top of the screen. Move cursor to the right using directional keypad until the little man with a box around his head is highlighted. Now pressing up and down on directional keypad, you should be able to highlight on / off with a white band? With desired option highted press 'ok' in middle of directional pad. That should now work.
Apr 29, 2009 | Samsung U900 Soul Cellular Phone
Samsung Le32r51bd
I have been having the same problem. It started as constant white dots obscuring the menu but as you hardly use the menu I left it. Then I had a row of white dots 5 dots high all the way across the screen about two thirds of the way up. This only happened on Ext1 and Ext 2. I tried 3 different Scart and A/V cables in ALL the possible connections in the back and still I got the dots. This has gradually got worse and I now have a screen full of flashing dots. With it being out of Warranty (18 month old) I have been referred to a company to repair it.
Estimated cost £263.37 inc VAT  Diagnosis: Needs a new PCB board Time to fix: 1 week
I shall update once I know more/final cost, on Wednesday.
In future I shall be taking the extended warranty out. :o(
Dec 02, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Wacthing sports -Tickers and scores are off screen in HD
skilled,senior tech needed to access servicer mode and check/adjust geometry/convergence. if unresponsive,then replace convergence and re-check geometry and alignment.
Sep 30, 2007 | Sony KP-51WS510 51" Rear Projection...
Samsung LE26R74BDX 26 in. HD-Ready LCD Television Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
