Question about Imation (01946) External Floppy Drive
Boiler ignites but goes out after about 10 seconds i can see fan running ok but ignition still firing when on main burn is it poss that air pressure switch fault or FDP fault ? or PC.          hariston sx 20 boiler
  • hubbbaboy12 May 11, 2010
    ok i will help
    Sergeant:
    Champion:
  • 247 Answers
It sounds to me as if the Triney Valve has let go, or it may even have burned out the Johnson Wheel. Sounds bad
Posted on Mar 21, 2010
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Boiler ignition is loud, boiler runs for a few seconds then goes out
flame sensor, air flow restriction or blower not producing enough pressure. clean the flame sensor to start. inspect venting, etc
May 13, 2013 | Jandy Lx Pool & Spa Heater - Electronic...
Boiler lights and runs Ok when first switched on, when it goes to reignite, it just keeps clicking (sparking) Pilot lights but boiler will not fire up.
This isn't very helpful at present.
What's the make and model of boiler?
Do you mean after the first (successful) ignition subsequent ignition attempts fail?
What happens if you turn the electrical power to the boiler OFF, then back ON ?
Feb 07, 2013 | Baby Gear
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
My dad has a valliant boiler VP4 ZE15 IT IS AROUND 3 YEARS OLD IT ISNOT IGNITING I HAVE TURNED PRESSURE UP AND HELD THE BUTTON IN FOR A MINUTE. i CANNOT FIND WHWERE THE RESET BUTTON IS TO TRY THIS PLEASE...
Turn the power off at the wall , wait 60 seconds and the boiler will automatically reset.
Modern boilers are complex re safety and the boiler will only start if the exhaust fan is running and is up to speed .
The vacuum caused by the fan trips a switch and allows ignition to continue
If the pilot light does not come on it does not warm up the thermocouple which turns on the main gas valve.
If you go to the Valliant website they will supply you with a user guide
Sep 28, 2009 | Water Heaters
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
Protherm 100EC boiler not firing up
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
Aug 23, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Fan runs continuously
the air pressure which does not controll the fan it is a safe guard for the gas/oil burner to ignite nowing that the fan is running ( air switch normaly negative /positive prssure n/o,n/c circuits. it could be that your boiler is designed for a cant think of techinacal name but when in centre of house/factory and has 1 or more boilers connected to flue etc the fans run when only power to boiler is on , non vented system ? it could be a simple link to remove in controll panel i would phone technical help for manufacture ?
Jan 31, 2009 | Water Heaters
Ariston eurocombi boiler not firing up. Thermostat lights all on upto 80 degrees as if overheating. Pressure fine. No fan, no ignition.
The fault occured a few days after I altered the radiator layout and then refilled the system. Intially the boiler worked fine, then a few days later all of the temperature lights light upto 80 and the boiler would not fire. The pump was working but the fan was not. After diagnosing the electronics I came to the conclusion it was either the contol pcb or the temperature probe. As the temperature probe was the cheaper option I replaced that first. The system is now working again. I think this fault was caused by me failing to completly remove all air from the system after refill and an air lock occuring causing the probe to burn out.
Nov 26, 2008 | Heating & Cooling
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Imation (01946) External Floppy Drive Logo
88 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
