Question about Jenn-Air JFC2089HE French Door Refrigerator
Sub zero gurgiling
My fridge notified me the condenser needed to be cleaned, since I did that it has developed a gurgiling noise. It is keeping cool, I'm worried this could be the prelude to a problem.
  • 1 more comment
  • senfred Feb 21, 2008
    Thanks for responding! Yes, the noise only occurs after you close the door, you must be psychic.
  • senfred Feb 24, 2008
    Is this something I need to worry about, it is a new sound, the unit is almost nine years old. It doesen't hapen every time I open the door, in fact it seems to be making the noise less and less.
  • Gary Davd
    Gary Davd May 11, 2010
    do you notice it only after you shut the door??
  • 770 Answers
The problem is the drain line sucking air back in the unit to equlize the pressure that is the noise you hear A dirty condenser has nothing to do with the noise just an FYI
Posted on Feb 23, 2008
  • Gary Davd
    Gary Davd Feb 24, 2008
    nothing to worry about plz rate this call
  • Gary Davd
    Gary Davd Feb 25, 2008
    Thanks
  • 4,889 Answers
Its not a problem.. The condenser works at optimum efficiency after you clean it.. trust me its not a problem..
Posted on Feb 20, 2008
  • eagle338
    eagle338 Feb 24, 2008
    That noise obviously varies because the condenser operation is varied by the thermostat depending on the temperature inside the fridge. The condenser has nothing to do with this.
How do i shut off and reset sub=zero 690 fridge?
Its not necessary when "Vacuum Condenser" light is blinking means That condenser is dirty. That light will come on if compressor running too long. Most common problem is that Evaporator coil in fresh food section is leaking freon. It still might keep temps ok, but compressor need to run much more to keep temperature you set. check back wall in fresh food section on left side at the middle, behind drawers. if you see moisture in one spot or a little bit of ice build up, then You will need to call people who can replace evaporator. It is pretty expensive fix. I made video how it looks to repair this problem. Thanks.
Feb 21, 2015 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 side by side the vacume the condenser light keep on flashing after 12 hrs or so but the condenser is clean it could be my both door are not flushed together .Fridge side door is little out may...
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Oct 18, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 side by side ,I have clean the condenser but vacume condenser keep on flashing .Turn the fridge off from the circut then on but same words are flasing after 12 hrs or so.Fridge temprature is...
MOST LIKELY FRIDGE SECTION IS LOW ON FREON! "VACUUM CONDENSER" WILL COME ON IF COMPRESSOR RUNS MORE THAN IT SHOULD BE. COMMON THING IS LEAKING EVAPORATOR COILS IN FRESH FOOD SECTION. CHECK MY VIDEO, I HOPE IT HELPS.
Oct 13, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 680/F The fridge is flashing "service"
Not filter but condenser coil thathe is next to compressor. Clean it out then check unit operation
Jan 26, 2018 | Sub-Zero 680 / F
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Mar 27, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Refrigerator not cooling
Please call Jon Larson in our Sub-Zero and Wolf customer service department at 800-222-7820. He will assist you in resolving the situation with your model 690.
Sincerely,
Diane E. White
Assistant Markeing Manager - Trade
Sub-Zero and Wolf
diane.white@subzero.com
Sep 18, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Jenn-Air JFC2089HE French Door Refrigerator Logo
97 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
