Question about Sub-Zero 695/O Side by Side Refrigerator
My Service light is blinking and there is an EC 50 code flashing. Can someone tell me how to fix the problem. I have tried turning the unit off and restarting it but the error eventually comes back.
Try powering refrigerator/freezer off for 1 minute and then repower back on which will clear the error code. If EC 50 rror code does not come back, it was posible you 1) had a house power failure interruption for a period of time and the compressor had to work extra hard to catch back up. or 2) also check to see that a door is not being held slightly ajar and is being blocked by food making the compressor run too much.
Posted on Jun 16, 2010
  • jay dawn Aug 31, 2010
    If error code returns, check for ice accumulalation on refrigerator evaporator which is located inside of refrig behind rear panel which is held by screws. If ice is present, check for oily residue in the long tray underneath evaportaror panel. That oil is from leaking freon which is common in the model with older copper evaporators.Check pressure and if low, replace with current evaporator which is aluminum and recharge with Freon.
    Sergeant:
    Champion:
  • 263 Answers
EC50 indicates that your refrigerator is running too much. Resetting it won't help. The problem will come back within 24 hours, as the control board monitors the run time of the unit. Most likely you have a bad condenser fan motor or a freon leak. Call for service asap!
Sub-zero refrigerator repair in Orange County, CA
Posted on Feb 05, 2010
What is the cause of a green light wit an s on it flashing in the dash and what does it mean?
trans is in sport mode on the shifter there is a button push it and it will go off push it again and it will come on again to inform you its in sport mode
Jul 30, 2014 | 1991 Honda Accord
D4 light on no matter what gear i'm in. 95 Honda Accord LX 4-cylinder. Already replaced solinoid, speedometer, fan,
The D4 light is coming on to tell you that there is one or more fault codes set in your transmission control module. The only way to retrieve codes on the 1995 models is to read "Flash Codes" output by the D4 light. (See instructions below)
RETRIEVING FLASH CODES USING THE D4 LIGHT
If fault codes are present, the D4 light will "blink" when the ignition is turned to the RUN position and will remain on at all times when the engine is running.
To retrieve the flash codes, turn the ignition switch off.
Install a jumper wire between the service check connector terminals.
The service check connector is a gray, 2-pin connector located on the PCM/TCM cover under the passenger side of the instrument panel. (See picture below)
CAUTION: DO NOT use the 3-pin located next to the service check connector.
Installing the jumper will place the PCM/TCM in diagnostic test mode.
Turn the ignition to the RUN position. Codes will be output by blinking the D4 light.
Note the number of blinks from the D4 light. A short blink indicates a single digit flash code. A long blink equals 10 short blinks. For instance one short blink indicates code 1. One long blink and four short blinks indicates code 14. If there is more than one fault code, they will be output one at a time from the lowest numbered code to the highest numbered code. It is recommended that you read the code or codes several times to make sure that you are reading it correctly.
Once you have retrieved the fault code(s) re-post your question and include the information for what codes you have and someone can then help you locate the cause of the problem.
May 22, 2011 | Honda Accord Cars & Trucks
Sub zero ref 690 s model with error code ec 50 what is that
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
My PT-AX100u will not turn on. The lamp is new, I have done the iris fix, which didn't help. When I turn it on, the green light flashes and after 30 seconds, it goes into shutdown mode and then one red...
Yes please call me Just went thru the same issue with my customers projector it involves more then typing can fulfill. Thanks Jordan Thomas
910 538 2754
PORT CITY AV
Nov 22, 2009 | Panasonic PT-AX100U-EC DLP Projector
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony trinitron stopped working-standby light blinks
How many blinks are you getting?. Blinking codes tells a service tech what section of the unit is manfunctioning.
The full service manual for KV-24fs120 can be found HERE!
Nov 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Error message on startup
The fuser unit could be the causes. But you can try this, power off the printer & unplug the power cord for 15 to 20 minutes. Power on after 20 minutes and se whether the problem resolves, if it ok, monitor it for a while just to make sure the problem resolves
Nov 20, 2006 | HP LaserJet 4 plus Printer
Sub-Zero 695/O Side by Side Refrigerator Logo
939 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
