Question about Refrigerators
Fan extraction of a Samsung Top Freezer refrigerator
I owe a Samsung top freezer refrigerator that because of the ice accumulation on fan working area it spoiled. I live in a lake border (Colbun Lake in Chile, Southamerica) where technitians are not available so I need to extract this fan, buy the replacement part, and replace it. I already melted the ice with a hair fan and noticed that although the refrigerator fan turns with the hair fan air, it does not work when I plug it on. I assume, because of the noice the refrigerator does when I plug it in, that the rest of it is working ok.
I really appreciate your help.
  • 4 more comments
  • ucalozano Feb 20, 2008
    I appreciate your quick answer my refrigerator Model is S369RVR-G-G.S as it is printd in the back tag, on owners instructions it appears as SR-369R(RV,RVU), made in Korea. Another question , do these models have an electronic plaque? Do I hareset it? if so , how should I proceed??, many thanks for your help
  • ucalozano Feb 21, 2008
    Do I have to reset the refrigerator? if so, how can I do it? At the back it has a turning nozzle that when I turn it I may turn the fridge on or off but I dont know at what point or where should it be positioned. Thank you.
    Could you please let me know how can i know if my fridge fan is really spoiled or if i have to reset the refrigerator to know, and how to reset it? I have a Digital Multimeter tester, how should I test the fridge parts??
    Thank you very much.
    there is no current supply to the fan
    Dear Sir, I must say i am really a Mrs. y tested for 220 AC voltage (Chile standard and 50 HZ), maybe i should test for a different voltage, should i? if so could you please explain me how? by now i have connected the black test lead to the "COM" socket and the Red test lead to the V omega mA socket then i connected the red prod to the pink wire and the black prod to the light blue or sky colour wire (both plugged to the fan), and then i switched on the refrigerator and no measurement appeared.
    Was it the correct way of doing it? Thanks for your help
    Dear Sir,
    I tried the Link thank you, I hope i can get some help from you. Do you know if I have to reset my fridge or how can i extract the fan?? Please it is very difficult to live without a fridge up here.
    Thanks
    Brigadier General:
  • Refrigerators Master
  • 3,614 Answers
Hi Sir,
How can i help you?
Posted on Feb 21, 2008
  • 1 more comment
  • micromaster
    micromaster Feb 21, 2008
    Test the wire that supply current in the fan, if it's good the fan have to be replaced a new one.
  • micromaster
    Is the ref is switch On? Kindly inspect the wires if it still soldered into the pcb board or some loose connection to the wire.
    If the wire is ok, and no such damaged then try testing in the mainboard parts there must be some IC / connector have defect that causing not to supply any current to the fan motor.
    Thanks,
  • micromaster
    Mam' if it's ok with you i'll post here a site where you can get some ideas, and advice me for some development or status.
    try this link for a while, when I also analyzing this problem.
    CLICK
    Let me know again later.
    Thanks
The refrigerator and freezer is not cooling
Few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Jun 25, 2010 | Westinghouse Refrigerators
I am getting a loud noise from the freezer compartment of my older, Kenmore refrigerator.
The noise may be a failing evaporator fan, but it's more likely to be ice that has accumulated around the fan and the fan blades are hitting it.
You will need to access the fan behind the cover in the freezer to check this out. The unit should be off so the blades aren't moving when you check.
Mar 19, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Samsung side by side refridgerator rs2630sh freezer not working other side is
Open freezer door, pull evrything out so that you can see back inner wall, look at plastic housing and see if you have ice/frost building from bottom to top of plastic cover, if so you have lost the ability to circulate air, drain possibly plugged up or evap fan not working or possible other cause. If you see ice/frost buildup shut refrig down for four days and let thaw (be sure to put towels aroundthe front of door area of freezer, the power back up and see if after starting if the fan comes on with the freezer door open and you holding in on door light switch(s). If fan does not come on within a few minutes of holding door switch(s) then evap fan is defective, call a repair tech or call samsung.
Oct 17, 2009 | Samsung Refrigerators
Can't get temp in fridge to go below 50 F. Freezer works fine and makes ice. It started when our area had a heat wave and the inside of our house was 85+ most of the day. The ice maker stopped working,...
Have you checked the evaporator fan(freezer fan), This problem is hard to detect because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator.
Aug 01, 2009 | Refrigerators
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Bottom is too warm
Make sure your fan is working ,its in the freezer behind panel .If not the fan your passage area is probably covered with ice and the air cant get in freezer
Jun 14, 2008 | Frigidaire FRT15G5CS Top Freezer...
Ice on the back wall of the side-by-side freezer and no ice
Possible circulation fan has quit, or defrost element is not working, call service.
Apr 20, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
