Question about Ovens
I'm a service man, and have a thermadore oven,
I'm a service man, and have a thermadore oven, Model #C302ZS the oven presents itself with an F24. I have changed the control panel & the glass touch panel two twice, with no luck.
The door gaskets are perfect as well as the hinges.
Help!!!!! what can be my problem?
  • 1 more comment
  • All Make Appliance Feb 05, 2010
    thanks for answering quickly. Can you please give me the part number of what you think I need?
    thanks for ur help!
    thanks for ur help!
  • 291 Answers
Wiring, or the relay board. Bad relays on the relay board can give the same code. On the older thermadores, we keep having to send the Erc and the relay board, as a set, in to thermadore to rebuild, as parts are no longer available. Bad wiring can also do this, although your new control panel and touch panel usually come with some new wiring. Our parts house shows the relay board as a part # 486909 for 188.10 retail. When we run into these jobs, we always advise the customer that the repair can be one component, or in a worst case scenario, all the electonics, as a power surge can easily damage them all. Some Thermadores have two relay boards, one for the upper oven, and one for the lower. This unit only has one. Good Luck. Appliance Specialists.
Posted on Feb 05, 2010
  • 506 Answers
This is a keyboard disconnected error according to thermador. Inspect the harness that attacehs the kepad to the control board, there could be a cracked or cold solder joint that momentarily breaks contact thus causing the error. Good luck, let me know what you find.
  • David S. Feb 05, 2010
    You may not need any part. I have see oven control boards before and most of the assemblies are two boards. One board has the controler and display, the other has the power electronics. There must be an interface error either between these boards. What is the interface between the two parts you have replaced? Is it a plug in connection, wire harness etc etc....
HOW TO REPLACE A HEATING ELEMENT IN THERMADOR OVEN MODEL PODMW301J
from what I find googlling it call a service man
Mar 14, 2015 | Thermador Ovens
Thermador over has f 24 code
fan/ air flow issue. search here for another post I did explaining the correction.
May 20, 2014 | Thermador SC272T Electric Double Oven
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
Code f24
shorted keypad. replace touch pad and relay board. Expensive!
Feb 06, 2013 | Thermador SEC302 Electric Double Oven
How to install air flow switch on thermadore c302zs
remove lower trim UNDER lower oven door. It's right there.
Dec 10, 2012 | Thermador C302U Electric Double Oven
I have a c302zs with f24 code i changed glass touch problem came back ???????? now what if you can also tell me the part #i have 3 ongoing just like this.my cust. not happy thanx ALL MAKE APPLIANCE
Hi
Thanks for using FixYa.
F24 error is caused when it is a bad touchpad. Heat will cause these buttons to stick sometimes. F24 means a key has been stuck for longer than 120 seconds. The random beeps means a button is opening and closing. When you warm your oven up it expands the buttons and makes it so a button is being held down so you can't push any more to turn it back on. The touchpad is the glass assembly on the front, and I think you’ll have to carry out the repair again and replace it with a new one as the old one might have been faulty. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 07, 2010 | Ovens
I have a Thermadore double wall oven, M# C302ZS. The oven is reading F24. I put in a new whole front touch pad, and it's still reading F24. What can be my problem??
I've copy and pasted an exert from this ovens service manual. try this and let me know of the results.
Good Luck
F-24 or F-25 This is caused by close contact to the control panel for more than 60 seconds,
appears in display window such as someone leaning against the controls or objects hanging in front of
controls.
F followed by 2 digits appears Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn
in the display window it back on.
Oct 29, 2009 | Toastmaster Ovens
I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Aug 17, 2009 | Thermador C302U Electric Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
139 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
